GP ULTIMATE 160/WHAT ENGINE SHOULD I USE????
SC
I have just purchased a Great Planes Ultimate 160.. I am at a loss as to which engine to power it with? OS 160 ? Saito 220? Saito 180? DA 50 ? Fuji Imvac 43EI ? OR WHAT????? I have read and heard sooo much GOOD and BAD on each choice. If any of you have any of these Combos, please share your experience and suggestions as to what power plant is best. Your Help will be greatly appreciated!!! MANY THANKS, WOODIE
My Feedback: (32)
RE: GP ULTIMATE 160/WHAT ENGINE SHOULD I USE????
ORIGINAL: wrpsr1911
Grab something to drink and have at it
http://www.rcuniverse.com/forum/m_32..._1/key_/tm.htm
I use a Brison 3.2 in mine at 16lbs and I'm well into 60 flights and loving it. I've only seen one report on the 160FX and he took that out and replaced it with a DA50. He liked the 160 but it was a bit lacking. Other tried Brison 2.4 and the Fuji 43 and all went into a 50cc engine
So what it boils down to, use a 50cc engine and you will not be disappointed. This is one plane that you really do not need to make changes to other than changing the hinges. I used the blue CA hinges and others used pinned hinges. That's about all the mods you need
So far everyone that has been a part of the thread I gave you the link to loves it. There even have been a few that crashed and they went and bought another. GP did it right with this one as well as the Cap232 160 (I have that one also) It's a typical Ultimate, takeff and lands like a big puddy tat and when you crank up the throws, it because a tiger but has no bad habits at all
There is also a review done on it with the Fuji. It's weight was 14.5 punds and he loved it. I originally had the 43 in mine but it came out at 16.75 pounds and I lost almost a full pound getting the brison 3.2
Here is a link to the review
http://www.rcuniverse.com/magazine/a...article_id=636
My Feedback: (198)
I'm on my SECOND Ult - both with 50cc.... BME, now Brison.... if you can do it, the 50cc class ANYFLAVOR (except the heavyweight anchor-conversion-way-too-heavy-for-the-power-they-put-out motors) will do WONDERFUL things with that airframe.
You just cannot imagine.....
My Feedback: (14)
ORIGINAL: aerobob
Could you be a little more specific in telling us which engine to avoid? <G>
MI
i see you used a brisson \what prop are you using with bipe just orderd one. took motor off mig 3 that hasent flown yet . have you flown plane yet. and have you had any problems with rfi as of yet
My Feedback: (32)
ORIGINAL: BSR
I have had no problems at all with RFI. Just do the standard RFI practices and you will be fine
My Feedback: (32)
BSR,
never run PCM to help fix a RFI problem. PCM only masks it until it gets so bad you will be worse off than PPM. I always use PPM for a few flights to verify I have no issues then I switch to PCM for the failsafe.
It's best to find the source of the problem first for any type of RFI
MI
the fri was with old radio and olg g62. since then new brisson new hitec radio and follewed protocall with all switches and keeping everything as far as possible from ing. so what your saying is rainge check which i did already with out any problems. but people said dont fly it without pcm reciever
My Feedback: (21)
NY
Haven't flown mine yet.. but I have a Moki 1.8 in mine. Couldn't afford a 50cc engine. The Moki 1.8 was in my GP Christen Eagle (which flew it nicely.. and pretty scale with scale-like aerobatic performance), so I bought a Brillelli 46 for the Eagle, and pulled the Moki out and put it in the Ulti Will post up how it handles once it's airborn
My Feedback: (198)
Ought to be pretty darn good with that MOKI.... but be prepared for a BIG glowfuel bill....
You'll enjoy it so much, you'll have to bring a drum to your field on a good day!!!!!!
My Feedback: (32)
I have no personal experience with the Moki but the people I have spoken with all say that's the glow engine to have next to the OS160FX. Since you are the first to offer a response on anything glow on this plane, please take the time to copy it into the huge thread going on about this plane. So far it's been all gassers and we would love to hear the glow engine side
My Feedback: (21)
NY
Copied from my blog...
Well.. finally had a chance to fire up the Moki and put that Ultimate in the air. It's going to be my new favorite airplane.. I can tell that already. I had motor problems though, for some reason, the engine flamed out both times I flew it. I had it running pretty rich, but it seemed like all of a sudden someone would just take the fuel right out of the line and the engine spooled down without one sputter of life.
I don't run a pump, nor have I ever with this Moki. The only thing I did differently in this installation though was not to use a header tank. I wonder if I put one on this ulti, if the problem would then go away? I know lots of people run pumps or cline regulators, but I didn't need one before, can't imagine why I'd need one now. Any thoughts?
Anyway, this bipe glides pretty well for its size!!! (thank God!!) No bad tendencies at all.. none! This is the first airplane I ever had that I actually needed dual rates and expo . There are a few coupling issues with knife edge, but with that large rudder, it's not really unexpected. I'm not into 3d yet, but I did manage to do walls and waterfalls without any real effort.. as well as flat spins. Thank the Lord that it's so stable.. I lost power on one of those waterfalls (test flight). The engine quit on flight number two on final.
As for power... I can't say yet.. I had that engine running slobbering rich, so it wasn't making optimal power at the time. With that said, it did seem to climb straight up for a LONG time until I cut the power. I'm sure power/weight will be ok, but not like it would be if I could afford a DA50
My Feedback: (197)
MN
ORIGINAL: deckerv
It would light the plug at idle at stop the glow at about 1/2 throttle. The transition became instant to full throttle in the air (it always ran good on the ground).
