Another Solatex Technique Question/Advise
o I am covering a Citabria Pro with a white base Solartex.
- Should I also paint the base white and then paint the red stripes on (ie: on the wing) or only paint on the red stripes.
* I am concerned with peeling off the white base coat when masking for the red stripes........I suppose I will have to wait a day or so f
or the paint to cure before masking and painting the stripes.
o Clear coating the edges of the masking tape will leave an edge where the tape has been removed. How is this prevented or
removed?
- Is the edge removed or filled when the clear coat is applied?
- Don't do anything until after the final clear coat is applied to everything then rub-out the paint for a smooth final finish?
Thanks for your advise and suggestions.
removed?
RE: Another Solatex Technique Question/Advise
I am by no means an expert. However I will try and give my opinion, I would aslo seek other opinions. First of all I think the Solartex and other tex's are great covering materials. I have always had a love/hate relationship with Monocoat that is more of a hate relationship of late.
-I would paint a light coat of white after cover. Let dry completely.
-Use HIGH QUALITY masking tape that releases easily. I use the blue stuff.
-Paint the red stripes on using light coats, just enough to cover.
-Some remove tape before paint dries, works ok if you are using latex. Fast dry sprays are a different story. Leave tape until paint is dry to avaoid a big mess!
-If you use cear coating to prevent paint creep then use a very light coat.
-I have had some success sanding the paint line with very fine wet sandpaper and then clear coating the entire airframe.
-Clear coating does help the paint line just a bit by smoothing it, but it will not elimate the paint line. I would not sand the entire painted plane.
_Build some test frames, cover and paint them to test the response of the paint you have chosen.
Hope this helps
JEB
Hope this helps
JEB
ORIGINAL: MOAJR
>Why not use the base color of the Solartex as the white ?
>If they have this where you are, use 3M brand BLUE masking tape.
>What you want id the "60 day safe release". It has a paper tape
>appearance and the adhesive rating on the side of the wrapper
>is 2 dots. This adheres well, yet will not pull up even fresh
>paint under it. Due to the porus weave/nature of Solartex,
>I suggest clearcoating the edges of the tape to prevent bleeding.
removed?
>as long as you don't apply the clear coating to the tape too
>thick, the edge/seam will dissappear when you clear coat
>the plane after.
>While Solartex is painted with a fuel proof paint, I suggest
>clear coating it to seal the weave and make cleaning easier.
removed?
>the plane after.
DR1, bps,CAMPY,
Thanks very much for all your feedback.
o Use Red Solartex for the stripes.
- I considered this, unfortunately, I only purchased the White Solartex. I will buy the Red and test to see if there is any
transparency in the red over the white. This certainly would save a lot of time.
* I am thinking of painting using both Red and White - is what I am leaning towards. It will add weight and , I think, both Red and
White Solarcoat surface will be/look more consistant in appearence.
o Using clearcoat when masking.
- I will take the advise to use just enough clear to seal the masked-line before painting the stripes; slightly wet-sand where the high
spots are and then clearcoat the entire part(s).
o The Paint.
I have experience using Krylon brand spray paint. I don't have any experience or knowledge using latex paints. I do like the
ease of cleaning up latex paint. Can Krylon Clear be sprayed over latex paint?
Thanks again for your mentoring.
MOAJR.
o The Paint.
MOAJR.
ORIGINAL: MOAJR
DR1, bps,CAMPY,
snip
o The Paint.
MOAJR.
I would not use the Krylon cleaqr as it is not fuel proof.
Latex is very easy to use (I do the majority of my painting with latex.) You can get a custom mix (for an EXACT match ) for about $8 - $10 a quart. I am including a basic "How To" for using latex. For clear coating you have a couple of options - Lusterkote (lacquer base) or Ultracote (enamel base) for fuel PROOF. A 3rd choice (a little pricey though) is the Nelson's products with the cross linker.
For non-yellowing fuel RESISTANT I suggest a water base polyurethane (Minwax Polycrylic).
There are a couple of caveats with the poly.
1. Let it dry for a minimum of 7 days before exposing to fuel.
2. Do not let the residue sit on the plane more than 4 hours. After that the poly starts to soften up. I have used the polycrylic on several planes, and as long as I follow the caveats I have no problems.
DR1, bps,CAMPY,
snip
o The Paint.
MOAJR.
Painting with Latex
First, if you have not done so, I strongly recommend you read the article
by Roy Vallencourt on using latex paint.
http://www.modelairplanenews.com/how_to/latex1.asp
I do disagree with Mr. Vallencourt in a couple of areas. These areas
of disagreement are based on my personal experience using latex.
1. I add 1 1/2 caps of FloTrol per quart of latex paint PRIOR to any
diluting. The Flotrol retards the drying slightly and allows the paint
to level itself.
2. Use ONLY water for thinning the paint. My experience has shown
that using windshield washer fluid gives a slight tint to light colors.
3. My best results with latex have been between 25 psi and 30 psi.
Under 25 psi I don't get the coverage I would like and over 30 psi the
paint starts to have a "dimpled" appearance.
4. I have not had good luck using a heat gun to promote quicker drying.
I know of several people who have had good luck using this technique
though. You can try it and see if it works for you or not.
5. I strongly suggest and highly recommend the blue 3M brand of masking
tape. What you want is the "60 Day Safe Release". This can be
identified by a paper appearance to the tape and on the side of the
wrapping is an adhesive index. You want a 2 dot adhesive rating. The
2 dot adheres reasonably well, yet will not pull up even fresh underlying
paint.
6. Flat latex will take an average of 7 - 10 days to "cure". Semi gloss
and gloss latex take 14 - 21 days to cure. To see if the paint is cured,
press your finger firmly on a hard area of the plane (I use the cowl
area). If a fingerprint remains, the paint is not cured. The
fingerprint will disappear in a day or two.
7. Gasoline powered planes will be fine with the paint as is. Glow
engine powered planes need to be clear coated. I suggest waiting until
the latex is cured before clear coating.
For clear coating I suggest one or 2 sprayed coats of a water base
polyurethane. My personal experience has shown that it is fuel RESISTANT
to 10% nitro and various reports indicate no problems with 15% nitro.
By fuel resistant, I mean if you let the clear coat dry for a minimum
of a week before exposing it to fuel AND you clean your planes at the end
of the day,you should have no problems. If you let the residue sit
overnight on the plane, it will become sticky. If you want fuel proof,
use Ultracote or Lusterkote clear. Oil Base polyurethane is also fuel
proof, but it will start yellowing in about 6 - 8 months. The yellowing
is not that noticable on dark colors, but very noticeable on light colors.
MOAJR-- how steady is your hand? Try painting them with a brush, using latex paint, WITHOUT masking. It's entirely possible, takes a little longer, BUT:
you don't have to worry about the paint bleeding under your masking tape (and it can happen even if you clearcoat the edge to seal it)
you don't have to worry about the raised edge along your mask line.
make a pattern for your stripes, or whatever pattern you choose, lay it on the covered plane, and very lightly pencil it onto the white cover (BTW, I wouldn't paint white what was already white). Then using a 1/4 inch flat camel hair brush, carefully start painting in the pattern outlines, just barely covering the pencil marks. Once that is done, use a larger brush where possible to fill in the rest of the pattern. You might need two coats in order to get a good streakless finish; then clearcoat with something fuelproof. I've been using LusterKote with great results. Here's two planes I've done this way. ALL the stripes and crosses on the DR-1 are freehand, no masking at all, and the checkerboard on the WACO, and the stripes (everything black) are also freehand. The DR-1 is covered in white Solartex, and the WACO is in yellow Solartex.
I did these planes this way because of the same things you said regarding bleeding under the mask and raised ridges. I have fairly severe carpal tunnel syndrome in both hands, but just took my time. I think the results speak for themselves.
Campy
I have saved a text copy of the MAN article "How To Paint With Latex" my Model Aviation "How To" folder.
This article is very interesting and informable. I will have to read it several times to fully understand the process and techniques.
Thank you very much for sending me the URL and for the additional advise and suggestions.
MOAJR
MOAJR
KHODGES
My free-hand painting technique, unfortunately no so steady, is not very good that is why I had not considered this very skillful method. This technique takes some practice and experience.
Thanks for those images of your finely painted aircrafts. Wonderful work!
MOAJR
MOAJR
