Receiver Question
WA
Receiver Question
Ive got a JR XS3 Radio. My question is, can i use any FM receiver with this radio? Im guessing i can, as long as its the same frequency and channel.
RE: Receiver Question
Common knowledge around here says 75MHz FM radios come in 2 phase shifts. Airtronics, JR, and Multiplex on one (So you can use Airtronics and Multiplex receivers.)
Futaba and Hitec are on the other so you likely can't use them.
I haven't tried this out myself, other than using an airtronics reciever with my XS3. I don't know what would happen if you used a JR or Airtronics crystal in a Futaba receiver though.
Yes there are basically two types positive and negative shift and they are not compatible with each other. Sorry but I cannot tell you which is which but I do know they are not compatible from experience.
