OS 46 LA
My Feedback: (43)
OS 46 LA
I have a Sig Fazer and it has a SuperTiger GS 40 on it. But i just bought a OS LA 46 and am thinking about putting it on there. Any suggestions? also what prop should i buy.
RE: OS 46 LA
I've had both engines, almost the same power. Super tigre may have a tad more power due to its roller bearings. My 2 cents, return the LA if you can and get a ST45 or a Tower 46, for about the same money much better power.
RE: OS 46 LA
That engine will be enough for your Fazer and a lot lighter than the ST so you may gain a small performance increase.
Put the biggest prop diameter you can with the shortest pitch. I'm tinking in a 11.5x4 APC like this:
http://www2.towerhobbies.com/cgi-bin...?&I=LX1564&P=0
Thats a good prop for that engine. What nitro fuel are you using?? Alttitude is very important too.
Anyhow try, experimentation is the name of the game.
Saludos.
PS Also try a Tower muffler for 46, can give you some RPM's extra.
Saludos.
My Feedback: (19)
RE: OS 46 LA
The 46LA will work fine in your Fazer. Use a 12x4, 11.5x4, or something similar. You also might want to experiment with different brands of 12x4 props to see which one you like best.
Unfortunately, the bolt spacing on the Tower muffler doesn't match the bolt spacing on the 46LA.
(See the plane hovering in my avatar? It's a Stickit IV with a.........<insert drum roll here>..........46LA.)
RE: OS 46 LA
ORIGINAL: HitecMan
I just ordered a apc 12.25X3.75 what do you think?
Let us know the outcome of your experiment.
Saludos.
My Feedback: (19)
RE: OS 46 LA
Will your Fazer fly with a 12.25x3.75 or a MA 11x4? Yes!
Will these be the best prop choices for a 46LA in a Fazer? Probably not, which is why they weren't mentioned.
The 12.25x3.75 will probably be too much prop for a 46LA due to it's very wide blades.
The MA 11x4 is probably a little small for a 46LA since MA props tend to overstate the actual pitch.
The MA 12x4 would probably be my first choice for a 46LA in a Fazer, then experiment from there.
The Grish white 12x4 works good too. This is the prop I'm currently using in a 3D Spad that's powered by a 46LA.
The APC 11.5x4 and 12x4 are nearly identical in performance and should work OK on a 46LA.
My best advice is to borrow or buy one of each of these four props and test fly them to see which one you prefer.
RE: OS 46 LA
ORIGINAL: Dave McDonald
Search the Glow Engines Forum for my thread OS 46LA Power Mods. The exact RPM data is in there.
If I can get the Tower muffler to bolt up--I can also bolt on a Macs black pipe from the OS 46FX. I'll do that tomorrow and post numbers if you guys wanna see them.
OH
RE: OS 46 LA
quote][/quote]
Hey Dave , hows the sig doing with the 46 l.a? I'm building one and will be useing my 46 L.A. I notice that the engine thrust line is not centered, about a 1/4" offsetis this a problem or will it be alright? This is my 2nd. build and 1st. profile.
