LA-40S Spraybar question
OR
Hi,
Its me again. Got my spraybar and venturi for the LA-40 today. Next question, what is the orientation of the spray-hole
in the spraybar to the engine? Is it supposed to point to the rear of the engine or the bottom? Anyone know?
Thanks again.
Bruce
Thanks again.
Bruce
RE: LA-40S Spraybar question
The hole should be pointing slightly down from directly across the venturi throat, turn it until the hole just barely disappears from sight and it doesn't matter if it's towards the front or back of the venturi. I usually make a mark on the inlet side of the spray bar in line with the hole so I can know where the hole is pointing without trying to peer down the venturi.
