transmiter batteries, use rechargeable?
Hey all,
i have the Savage x.. the transmitter takes 8XAA batteries, which equals 12V..
is there any way of using rechargeable batterries in there?? they wont equal the voltage of alkaline batteries, will this matter??
cheers
cheers
RE: transmiter batteries, use rechargeable?
The small drop in voltage will not make that much a difference. I use 8 Duracell 2300mah nimh batteries and it works great and they last a lot longer than the alkalein batteries. You may have a shorter range with the radio, but the alkalein batteries drop off very quickly and you will get a longer more consistent runtime with rechargeable nimh's.
I'm using the Energizer 2500mah NIMH rechargeable batteries in the transmitter and for the receiver pack.....they work great. You can buy them at Sam's Club.
A good set of Nimh will be better than alkalines. Alkalines quickly drop in voltage while the alkalines hold theirs until they are nearly dead. There's no down side to using rechargeables in your radio.
perfect..
and on that, what is the best way to charge them..
i have bought 8 X 2700mAh batteries.. i have a AA charger but it will charge up to 2500mAh..
should i just get a 8 battery holder, place them in there and connect them to my Pro Peak charger??
ORIGINAL: Roy_e
perfect..
perfect..
ORIGINAL: Roy_e
perfect..
perfect..
Most of my radios have charge jacks but I seem to get a better charge if I take them out and hook them directly to the charger.
ORIGINAL: gravedigger
The Energizers I use came with their own charger....it takes 8 hours to charge 4 AAs so I picked up an extra charger.
ORIGINAL: Roy_e
perfect..
perfect..
I use the Rayovac 15 minutes. I can have all 8 charged in well under an hour. They last the whole day then some.
