JMP 3000
JMP 3000
This is the JMP 3000 for the U.S. market, now available from Tom Cook
through Jet Model Products.
[email protected]
TJT/ARTES/JMP are currently working on some custom limited edition colour combinations for the JMP 3000, which look quite impressive in a red and blue finish. I will post these shortly as well...
Cheers - Marty
[email protected]
Cheers - Marty
JMP3000
One of the distinctive external features of the TJT/ARTES/JMP turbine range apart from having aluminium outer cases, is another obvious innovation and advantage of the outer case antislip recesses. No more chance for the turbine to slip within the mounting bracket. This is unique to TJT/ARTES/JMP microjet turbine range ...
