Motor Saver Mod
Old 05-26-2006, 10:23 PM
Toxik
Default Motor Saver Mod
A couple weeks ago I bought a motor saver air filter and went to go try it out and found that the gap between the filter spout to the carb and the spur gear was really small. Well, wouldn't you know, after I ran the truck I looked at the filter spout and saw that the spur had cut right through it. As I was contemplating having to buy another Air filter, I though I would crazy glue the motor saver filter to the stock Traxxas filter spout. It fits great. Glue works really good. I was a little anoid in the design of the motor saver spout. Has anyone else had a problem with theirs and what did you do about it?
Old 05-26-2006, 11:46 PM
Rob6
Rob6's Avatar
Default RE: Motor Saver Mod
I would check the engine for shavings... My dad had that happen to his REVO and it KILLED the motor...
Old 05-27-2006, 02:06 AM
LJ NITRO
http://www.misbehavin-rc.com/pit-lan...air-filter.asp this is what you need to do
Old 05-27-2006, 10:53 AM
Toxik
Great link, thanks eh. If the glue job doesn't hold then I will try this approach.
Old 05-27-2006, 10:12 PM
sfleuriet
sfleuriet's Avatar
My spur put a very very small hole in the neck of the air filter. I'd like to get a new one of those necks, but I don't know what. I should probably go put a dab of glue on that hole so it doesn't F stuff up.
Doing that mod wouldn't help me would it? It still uses that same neck which is VERY VERY VERY close to the spur.
Old 05-28-2006, 03:47 AM
LJ NITRO
that mod uses the stock neck and the Motor Saver filter housing. that way it sit the same as stock. just get a filter assembly off ebay
