emaxx motors or batteries?
my girls emaxx seems to be slower than it used to be and I was woundering if their is a way to tell if I need to change the motors or if its the batteries. I drove her truck in the pond behind our house on accident about a month ago but it seemed to work fine after it dried out, could this be the cause of it, any suggestions will help.
Banned
RE: emaxx motors or batteries?
try to cycle the batteries. drain them down so the truck will BARELY move, then give them a full charge. you could of damaged the batteries. as far as the motors go. get some electronics cleaner and give them a good spary, you can also use wd40 for the motors but im not 100% on the WD40. but the electronics cleaner is made for that.
Timmahh
Timmahh
I have tried to cycle the batteries and that didn't help, I will probably try to clean the motors next. Can you suggest a good cleaner. thanks
