Thread lock info
Thread lock info
So, where do you use threadlock? Where do you *not* use it?
A few things I already know, like red is permanent, blue is what we generaly need, but there are things I'm not sure of.
Like, should I use it on shock caps? On wheel/lug nuts? Avoid using it on nylon nuts?
AB, CANADA
RE: Thread lock info
Generally, thread lock is for metal to metal contact only. I suppose you could use the weak threadlock on plastic, but it isn't advisable.
Nylock nuts shouldn't need threadlock, as they are not very likely to back off.
But really anywhere a screw goes into metal, medium or low strength threadlock is a good idea.
PA
I generally use it on any metal to metal parts. Another words where screws and that thread into a metal parts. Like the motor mount screws and the clutch nut on the crank shaft. But i dont use them on any nit that has nylon on them like the wheel nuts and the shock bolts on the shock towers (for the losi's).
But i would not use it on the shock caps. But thats all i can think of for now
1 Post
ORIGINAL: con69
can u use lock tight on the engine exhaust because i herd that you carnt use it were it gets hot. but the screw always comes out
As has been said, use blue thread locker on any metal to metal contact. Don't use it on the plastic parts like stock shocks. It is suspoesed to weaken the plastic, idk, I don ues it there to see.
Now, having said that, I could not keep the wheel nuts on my LST (nylock nuts) so out of desperation I tried blue locktite and have not had a wheel come off since.
My CRT has no nylon on the wheel nuts, so I guess I'll use it there as well. Then I also won't have to crank them down stupidly tight, and I won't crack the rims. The tires came pre-glued, so I can't boil them now.
Thanks everyone,
Raketemensch
Thanks everyone,
Raketemensch
