Fuji gas engines
Old 12-03-2002, 05:37 PM
Capt. Crackup
Default Fuji gas engines
GY, does the Fuji appear to have as much power as advertised? What kind of RPM do you get on the 20x 8???????
Thanks. Skip
Old 12-16-2002, 11:16 PM
3dd
3dd's Avatar
on my bt 50 i put a 3/4 inch cork in the volocity stack turn the ingnition off i repeat off then open the throttle 1/2 way pull it thru 6 0r 7 times get it wet. close the throttle to 1/3 or a little less ,flip it thru briskly as it will not start if you turn it slow
Old 12-16-2002, 11:18 PM
3dd
3dd's Avatar
last saterday 90% himidity on a 20x10 i got 19 pounds trhust at 6800 rpm on a 20x8 i get 7400 at 18pounds of thrust
