ESC motor Limit
ESC motor Limit
If an ESC has a motor limit up to 15 turns (at 6 cells) what does that mean I can't go lower then a 15 turn motor or I can't go higher? also what does the 6 cell mean? is that the battery size?
MA
RE: ESC motor Limit
ok motors are rated in number of turns or the number of times the wire is wrapped around the armature. The lower the turns the higher the RPM. A 15T ESC will be able to handle motors 15 turns and up. Not 14 or less. 6 cells means there are 6 individual batteries in the pack that are wired in series to create 7.2V.
RE: ESC motor Limit
yea I knew what the turns meant, so does that mean I CANNOT use a 7 cell battery or what does that mean, does the limit change if I use a 7 cell?
RE: ESC motor Limit
RE: ESC motor Limit
I have the same ESC, at 7 cells the motor limit is 1 turn higher than the 6 cell limit, it will be 16T at 7cells, 15T at 6 cells. It will also depend on the quality of motor you are using. If its like the cheap ones like orions, fireballs etc. you can probably get away with 15T at 7 cells. That ESC is equiped with thermal protection, you could probably try going lower and hope that it will just cut-off if its runnin too hot and not ruin your ESc.
For Novak question, their website's customer support has been very helpful to me. You can email them direct for questions on any of their product.
http://www.teamnovak.com/cs/contact.htm
RE: ESC motor Limit
I am lookin to buy a new motor and I had an Nitro car and in nitro's the ORION's where really good so I WAS gonna buy a orion for a motor but as you seeing them not that great of quality may I ask you what motor's are of good to great quality?
PA
RE: ESC motor Limit
I have an orion revolution I run in a T4, good quality........ The brushes are a bit of a pain, but I like the speed and the brushes last.
RE: ESC motor Limit
Sorry to Generalize Orion as not so good ones, I only meant the cheap ones they sell for about $10.00 bucks, but they do make good quality ones too that are competitive.
RE: ESC motor Limit
Yea I was thinking about one around the 40 range do you have any suggestions? I was thinking around maybe the 17-19 turn range.
RE: ESC motor Limit
Does anyone else have any more opinions on the kind of motor I should get? I really want something that has a good amount of tourqe but can atleast get up to 25 - 35. I will mess with the gearing so I just want a nice reliablie motor. I was thinking about a peak peformance raven 19t.
