Powerbox EVO/Duralite/P51
My Feedback: (24)
Working on the TF Giant P51. I had planned on using a Powerbox EVO 40/16 (primarily for its redundant battery setup) and Duralite batteries (2 1900 mah packs) I noticed that the battery leads (into the Powerbox) are 22 guage wire. I just want to confirm that this is adequate for the current. I will be using 9 servos (4 are digital). Thanks. Bob
My Feedback: (17)
AB, CANADA
RE: Powerbox EVO/Duralite/P51
Bob,you have to buy the powerbox batteries...They have 16 guage wire and have a male multiplex connector on them to plug into the powerbox....I believe you will have to buy their 2000 mah powerbox batteries.
Jack
Jack
You can buy the Multiplex connetors at a good hobby shop. Then get the Lipos from who ever you want and use the 16ga wire. The battries you might buy from whom you got your powerbox will almost cost the same as the powerbox .
ORIGINAL: BalsaBob
