Reverse module broke
My Feedback: (29)
IA
I have had a Reverse mod in my X for several months. I have only used it a few times but it has always worked well. Yesterday I was driving alone and I suddenly lost power. The motor was running fine, just not going anywhere. When I tore it down I found the 87035c gear broken lose from its shaft. Has anyone else had this happen? Is this common? I guess I would not think much about it, if I had been beating it around but I wasn't in fact I had not even used rev. that night.
My first picture is what it should look like. Second picture is after the break.
Thanks for any help
Ton
Thanks for any help
Ton
RE: Reverse module broke
Same thing happend to me awhile back. But that was due to servo glitching. The area that I was in had 'dead" spots so when truck would go to these spots, it would twitch the reverse servo and kick in reverse while still moving forward. Broke what's in your pic and 3 tooth on the gears itself. Good thing the tranny gears were intact. Rather buy a reverse module than a tranny. Needless to say I upgraded to DSM and never had the glitch issues anymore. I do know they sell the individual part that you broke but I recall a whole new reverse module was a few more dollars than the part and was not worth getting just that part. At least you would have spare parts if buying the whole kit.
Good luck.
Good luck.
Bam bam hit this one on the head.
Even the slightest servo glitch can throw the 3rd channel into reverse enough for it to engage, causing a fouled up mess of the module.
If you insist on running reverse use an FM tx & rx at the least. AM radios tend to glitch alot
ORIGINAL: benzzyo5
that happned to me cuz i was switching to reverse when still moving forward[:-].
Hey Ben, do it again and let us know what happens....
My Feedback: (29)
IA
The broken part is steel. I use a Futaba 3PJ radio with the DSM module and it was not glitching. I use the 2 position knob on top of the transmitter to shift from forward to reverse, and it had not moved. I sent a letter to HPI support about this and they want to inspect the part. May be good news. I am going to send it to them today. I will let you know what happens.
Ron
Ron
ORIGINAL: 4 stroken ron
Let us know how it turns out. I still have that broken piece... maybe I can get a replacement for free... [wishful thinking]
