will these two work together?
ON, CANADA
i have recently burned my ESC unit, so my car is out of commision, i played with it not even an hour.
currently i have a 16T intellispeed ESC unit with the stock motor.
i want to purchase the following motor and ESC unit, my question is that will i be okay with these two?
also will the ESC unit work with a 27Mhz Acmos Technisport Hiyabusa ?
Motor.
[link]http://cgi.ebay.ca/Tamiya-RS540-Sport-Tuned-Motor-49-62_W0QQitemZ280002141867QQihZ018QQcategoryZ34063QQ ssPageNameZWD1VQQrdZ1QQcmdZViewItem[/link]
ESC( will it work with my remote?)
[link]http://cgi.ebay.ca/NEW-TAMIYA-TEU-101BK-ELECTRONIC-SPEED-CONTROLLER-ESC_W0QQitemZ300003036287QQihZ020QQcategoryZ44022Q QrdZ1QQcmdZViewItem[/link]
i'm a big noob to this stuff, and i really want to get this car going so i can atleast play with it.
all the help is appricaited.
Motor.
RE: will these two work together?
I have researched this motor, and there are two types that I am seeing posted in different sites. One at 27turns, and one at 23turns. There are more people saying the it is a standard mabuchi with an advance timing meaning its 27t. If this is correct, then the TEU-101BK would be fine.
If its 23t then you will need the TEU-302BK.
Personally I think its a 27t, its the super stocks that are 23t.
And Yes It will work with your radio receiver, just make sure you are using the correct rx plug from the esc, or just re-arrange the 3 wires to match the rx. red +, black -, white signal.
ON, CANADA
thanks that clears it up.
as for the motor, i'm just going with what i saw in the Tamiya catalouge.
it doesn't say on the ebay link that how many turns the motor is :S
