Evolution 45GX2 LOVE IT OR HATE IT
Old 07-07-2006, 06:22 PM
hunternfla
Default Evolution 45GX2 LOVE IT OR HATE IT
WHO HAS IT AND DO YOU LIKE IT OR HATE IT AND WHAT PROPS ARE YOU RUNNING
Old 07-07-2006, 07:57 PM
closetguy
My Feedback: (13)
Default RE: Evolution 45GX2 LOVE IT OR HATE IT
I GUESS I'LL BE THE FIRST, IKNOW A LOT HAS HEARD THIS BEFORE,I LIKE IT VERY MUCH,VERY SMOOOOTH,VERY FAST THROTTLE RESPONSE WITH THE SMALLER PROPS MEJZLIK 22-8 IS THE BEST FOR ME,MSC 22-8 IS NICE ALSO,STRONG VERTICAL,JUST NOT AS FAST VERTICAL AS THE MEJZLIK,EASY STARTING,I FORGOT TO SAY IT'S A MVVS 45
MEJZLIK 22-8 7250
MSC 22-8 6800
ONE GREAT ENGINE EVEN IF IT DID COME FROM CHINA!
ENJOY!
Old 07-08-2006, 03:15 AM
cyprusjets
cyprusjets's Avatar
You mean from Czech Republic!! Love it, no need to say more.
ORIGINAL: closetguy
Old 01-07-2007, 10:28 AM
ryan_m
ryan_m's Avatar
Wow, only three posts in several months? Does nobody like this engine or what?
Anybody know an all up weight of this engine, ignition, and pitts style muffler?
Old 01-08-2007, 06:46 AM
Greg Cothern
My Feedback: (8)
Greg Cothern's Avatar
I have the MVVS 45 as well and absolutely LOVE it!!! I concur will the previous statements on its characteristics. I am running a NX 22X8 prop with a wraparound BCM pitts muffler and straight out of the box 6500 rpms. Have ran about a gallon and a half and it is getting stronger will tach it probably at 2 gallons to see what it is running.
I like it so much I picked up another one!!! Awesome!!
Old 01-08-2007, 10:54 AM
Hans Meij
Love it too. First engine (after a ZDZ40 and Brison/Revolution52) on a 2m ship that does not shake it apart. Smooth and powerfull.
Mejzlik 21*11,5 3b / 6300 rpm / Krumscheid 86 can on MTW header
Old 01-08-2007, 07:34 PM
p-80
any video of one running
Old 01-11-2007, 11:22 PM
ggroyal1
ggroyal1's Avatar
Here is mine and it runs great.
ID:	596018   Click image for larger version
Old 01-12-2007, 07:43 PM
fiery
Hans
I am looking for a ship like the Agressor 240 shown in your post. Is it an ARF? Who is the manufacturer?
cheers
fiery
(Owner of 2 MVVS 1.60 red heads ... luv 'em)
Old 01-12-2007, 09:13 PM
tailskid
My Feedback: (34)
tailskid's Avatar
ggroyal1, I have the 45GT not the 2x version in the same plane-yet to fly it. Having trouble starting that puppy. Once started the throttle seems 'either/or'...fast idle or full speed.....suggestions?
Have you flown yours yet? What prop you planning on using? Nice spinner....type?
Old 01-12-2007, 10:37 PM
ggroyal1
ggroyal1's Avatar
The plane is a Hangar 9 Cap232g(27%) from Horizon Hobbies. It cost less than $400 and is a very good ARF. It has a 22x8 prop and a Truturn 31/4 inch spinner. It has not been flown, waiting on a very calm day for the first flight. There are videos of this plane on RCU. I am using a JR7202 radio and JR servos (ds8411 & ds8611a). This is my first gas.
George G. Royal
Old 01-13-2007, 03:16 AM
Hans Meij
ORIGINAL: fiery
On my site there are some links.
http://home.hetnet.nl/~meijhmb3/proj...r/agressor.htm
The manufacturer is Topmodel CZ and it availble as ARC and ARF
http://www.topmodelcz.cz/
I bought it on the Dortmund fair from this shop:
http://www.modellbau-bichler.de/
See the vid. from Henke
http://henke.rchomepage.com/
Old 01-13-2007, 09:02 PM
BillJ
My Feedback: (19)
BillJ's Avatar
Great little engine BUT....First time broke a piston ring which did no damage.Returned for warrenty repair......2nd flight after that repair .broke a piston ring which broke piston rod Jug and under warrenty cost them a whole new top end.......Have not run it since........ I run 40:1 Beray in all my gassers........no problems except this one....It is in a Great PLanes Ultimate........... FWIW
Old 04-09-2007, 12:17 PM
Baphomet
Hi !
I have the Mvvs 45 mag with Ks silencer till 65ccm , headerlength is 26cm , diameter 25mm .
It swings a 21x11 3bl Engel carbon at 6800 rpms , with manufakturer needlesetup and 1:30 fuel after a half gallon through . It's waiting for it's maidenflight !
I love it !!! [8D]
This engine needs big props and a canister on low rpms to give max power , it's not a screamer for higher rpms than the midrange of 6 k ! After fully breakein , i will use a Engel 22x10 3bl .
Old 04-09-2007, 07:33 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Mine is getting much easier to start! Pulls the H9 232G around very well!!!
Old 04-10-2007, 06:33 AM
BillJ
My Feedback: (19)
BillJ's Avatar
UPDATE,
A couple of friends at our field have had the crank bearings go bad... If you see any black goop coming out of the front of your motor IT IS GREASE AND bits of the casing .....
Anyone else having this problem ?? I've had about 6-8 flights on mine since being rebuilt for broken piston ring which seixed the engine...... These are all NEW einges with less than 5 galloms thru them
Old 04-10-2007, 06:45 AM
BaldEagel
BaldEagel's Avatar
Someone asked for a vidio of one running, this is a vidio of the comparison between a Brison Pitts wrap around silencer and an MTW 75 Cannister installation, the cannister gave 1150rpm increase without touching the needles: http://media.putfile.com/MVVS-45-Mag...-and-Cannister note the burballing at full throttle with the pitts silencer and the clean pick up with the cannister, these engines definatly need a free flowing exhast not a back pressure system like the pitts wrap around. The vidio was with a wooden 22x10 on its first gallon of fuel at 30:1.
Mike
Old 07-29-2007, 07:57 AM
RadarController
I just got a GP Cap27%. I'm looking at powerplants and I've never had a gas. I want your guys thoughts. This is the new 4 Stroke OS200 that weighs 30oz with muffler. I've read some of the rpm's on the above posts. Just tell me what you think. I want to do 3D. Eye level hovers w/ authoratative pull out. Just like I do with my little planes. Nobody has a gas or large scale where I fly. With a gas.. This plane will weigh out to be about 13 1/2lbs - 14lbs. With this engine it would be around 12 1/2. I realize the benefit of gas price/clean up. Trying to get somebody to talk me into gas.
os200:
18x6 8,920
18x8 8,360
18x10 7,340
20x6 7,230
20x8 7,230
Old 07-29-2007, 09:03 AM
MikeEast
MikeEast's Avatar
Which engine are you wanting to discuss the OS 200 or the Evolution 45GX2?
Old 07-29-2007, 09:10 AM
JUGFLIER
Radar Controller,
I have the GP Cap 232 also. I never flew it glow. I started with a Fuji 43ccbi which flew it well, but just not quite enough pullout in a low hover. I just bought a DA-50, got it thursday, and when i put the fuji on my scale and then the DA, the DA is a half pound lighter. That will put my plane @ 13 1/4 pounds. With the fuji it flew much like a big foamy, can't wait to see it now. IMHO, the Evolution and the DA are the same price, I go with the DA. I've had an evolution.
There is thread in the 3-d section on this plane and different set ups, you need to read, some great info over there.
Old 07-29-2007, 09:18 AM
MikeEast
MikeEast's Avatar
I dunno. From a performance standpoint the DA and the Evolution are pretty much a wash. So it just comes down to preference. DA probably gets a slight edge because it such a proven workhorse, but I have an Evolution and I see absolutely no reason to switch to DA.
Old 07-29-2007, 09:40 AM
ggroyal1
ggroyal1's Avatar
I have the Evolution 45gx2 in the H9 Cap232g. I have been flying it for over seven months. It cranks after 3 flips and I have never had a dead stick. It is still set at the factory settings and it runs great. I use 93 octane gas with a 40:1 Mobil1 2T racing fully synthetic oil.
George G. Royal
Old 07-29-2007, 01:29 PM
RadarController
1/2 pound lighter and 1hp more on the DA. Two different animals.
Old 07-31-2007, 05:00 AM
BaldEagel
BaldEagel's Avatar
Don't know where Radar gets his figures from but I guarantee the MVVS 45 Magnezium weight is under 3Lb with the plug in and turns a 24x10 @ 6200rpm or a 22x10 three blade at 5900rpm I have one and use it without any trouble at all, pulls a 2M Edge around like it weighs nothing, its over 7KGs.
Mike
Old 07-31-2007, 05:10 AM
ggroyal1
ggroyal1's Avatar
BaldEagel,
You are correct, the Evolution/MVVS 45gx2 is 2.84375 pounds and is 5.2HP
George G. Royal
