Need to make foam inserts for 4" Robart Tires... HELP?
Hello Everyone,
I need to make some foam inserts for my 4" robart tires... any one done this before successfully ?
Have any suggestions ????
Rick,
Rick,
RE: Need to make foam inserts for 4" Robart Tires... HELP?
Hi Terry,
Foam insulation rod... I have not seen that before? Can you explain a bit what that is?
Rick,
Rick,
My Feedback: (65)
Home Depot sells it. Called "Caulk Saver" because you fill the crack almost all the way with it before finishing off with caulk. At my Depot it comes in 3/8" and 1/2" diameters. Stuff as much of it into the tire as you can and still be able to put the tire back on the rim--end result is a nice firm tire that doesn't get flat spots.
Guys !
Thanks for the quick and awsome response... I will be heading down to Home Depot tomorrow morning for some "Caulk Saver" !.
I appreciate all fo the help as always :-)
Rick,
Rick,
