VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
MAMO UPSIDEDOWN VPP
Old 07-14-2006, 02:03 AM
MikeBiv
Default MAMO UPSIDEDOWN VPP
Horizon has this in stock.
Says it doesn't need a hollow shaft motor, and there is replacment blades available.
Anyone Familar with it?
http://www.horizonhobby.com/Products...?ProdID=MAOUSD
From Site-
High quality German made product- only system of its kind!
User-friendly design is easy to set up and maintain
System does NOT require hollow shaft motor. This system will work with E-flite Park 300-400 systems as well as other outrunner motors on the market.
Smooth running
Durable and very light weight
Unit contains (2) 2 x 12mm screws that will bend in a crash and prevent damage to the main unit. Replacement screws are available and easy to install.
Blades can be replaced in a matter of seconds without having to re-adjust settings- this makes other hollow shaft systems harder to set up and maintain.
Support parts available for the unit
Included in the system are two sets of blades (8 & 9”) complete assembly/setup instructions and carbon motor mount
Old 07-14-2006, 05:41 AM
3DForrest
Default RE: MAMO UPSIDEDOWN VPP
Yes It is Martin Muller design. Ans if you don't know who he is he is thge designier of the sockflyers.He used it to win the German Indoor Champanships.
Old 07-14-2006, 06:00 PM
MikeBiv
it looks like this is the one to get!
Thanks for the info.
Old 08-09-2012, 08:03 AM
Nik_O
Hello,
does anyone know where in Europe is on stock this system?
thanks,
Nik
Old 08-31-2012, 02:34 AM
wvr
wvr's Avatar
Hi Nik
I have a new set of the MAMO upside down which I'm not gone use
If you are interrested, let me know we can work it out ;-)
Winfried
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
