HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
WATS DA BEST WAY TO LOCK DA DIFFS??
Old 07-15-2006, 09:06 PM
savage_guy
Default WATS DA BEST WAY TO LOCK DA DIFFS??
WHATS THE BEST EASIEST WAY TO LOCK THE DIFFERENTIALS
Old 07-16-2006, 01:09 AM
JayC1968
JayC1968's Avatar
Default RE: WATS DA BEST WAY TO LOCK DA DIFFS??
ORIGINAL: savage_guy
Do NOT lock your diffs. Plain,Blunt, To the point. Just shim them bro....... If you lock any diff, make sure it's the rear ONLY..... your turning will suck but....... it's on you...
There are lots of diff lockers out there, but I always just oied mine up at 100k to give a locked attitude to the diff,
Old 07-16-2006, 09:20 AM
Revo Eater
Revo Eater's Avatar
Use a spool.
Old 07-16-2006, 01:08 PM
black mamba
black mamba's Avatar
Get a aluminum locker from Maximizer. I have one and it works great. I recommend upgrading to their aluminum diff cup at this time too because the stock diff cup is plastic.
Old 07-17-2006, 09:37 AM
gerwen
gerwen's Avatar
I heard silly putty in the diff works pretty good, and isn't permanent.
Old 07-17-2006, 03:38 PM
bam.bam
ORIGINAL: bumperdragger
Maximizers diff lockers are good but like you said, get the alloy diff cup as well. The stock plastic cups do wear in time and flex during hard turning and take offs loosening the tolerances within the cups.
A better upgrade, in my opinion, is the [link=http://www.vertigoperformance.com/products_Lockers.html]Vertigo Performance Diff Lockers[/link]
Reasons are:
1. Does away with the Diff cup altogether.
2. Cheaper (only $20) than getting the maximizer alloy diff cup AND locker (maximizer price 0f 40.22+22.95=63.17)
3. More durable
ORIGINAL: gerwen
Yeah, that works but wears out after awhile. If you're inside the diff, which hopefully you are not offen, do it right the first time because you will be back in there when the putty whears out. Then what??
Old 07-17-2006, 03:44 PM
Chronic
ORIGINAL: bam.bam
Reasons are:
3. More durable
ORIGINAL: gerwen
That is more than likely the spool that Revo Eater was referring to. That would be the best way to do it.
Old 07-17-2006, 03:55 PM
bam.bam
Chronic, A Spool? what's that?
Old 07-17-2006, 04:45 PM
Chronic
The terminology used with RCs is sometimes misleading if you have any background in 1:1 vehicle mechanics. They call that a locker, but it's actually what's known as a spool. The solid chunks of aluminum that other comapanies make to go inside the stock diff cup are not lockers either. They are more like mini-spools for 1:1 vehicles. A spool replaces the carrier and keeps the two axle shafts locked together at all times. A mini-spool does the same thing, but it mounts inside of a gutted stock carrier instead of completely replacing it.
A real "locker" does the same thing, but it also has the ability to unlock when coasting or turning while off power in an attempt to lesson the ill handling. This action can either occur manually or automatically, depending on the design of the unit.
The "limited slip" effect that you get from using heavier diff fluid is the most accurate cross-over term. Limited slip in 1:1 vehicles is achieved with some sort of friction setup, but the end result is about the same. The old term "Posi-traction" refers to a limited slip unit. It was actually a trademarked name owned by GM and used for some of their LS differentials.
Old 07-17-2006, 05:47 PM
Revo Eater
Revo Eater's Avatar
Well put!
Old 07-17-2006, 07:04 PM
azzman
azzman's Avatar
I say go cheap...hehe silly putty sounds good, or JB weld, epoxy etc...I wpould only used the JB weld etc option if my diff needed rebuilding, or you have some old gears lying around from a previous rebuild...
Old 07-17-2006, 08:21 PM
the dog
if i had a 1$ for every broke or worn gear laying around........
Old 07-18-2006, 02:56 AM
black mamba
ORIGINAL: bam.bam
Reasons are:
3. More durable
Damn, a day late and a dollar short. I wish I had seen this before I bought the Maximizer setup. If I have any problems with what I have now, I'll surely go with the Vertigo at that time.
Old 07-18-2006, 09:44 AM
bam.bam
Sorry bumpergragger, I know you bought your Maximizer stuff already and did not want to rain on your parade.
chronic, revo eater: Any of you guys have a link to this spool that applies to the Savage? thx.
Old 02-17-2008, 10:48 AM
black mamba
Update....I got rid of the Maximizer and have since gone with Vertigos up front and in the rear. Vertigo no longer makes the Savage locker, so you'll have to find them on ebay, etc.
http://cgi.ebay.com/Vertigo-Performa...QQcmdZViewItem
