s/m f18 c cg after 20 flights
i've had a few pm's about my setup on s/m f18c so here it is; cg at 25mm (1 inch) BEHIND front spa, with rear tanks full and gear down, i drain front to rear to header,and land after 7 mins in this config, aileron 20mm up, 18 down, elevator 40mm up, 25 down, rudder 30mm. also note foto of crack on fuse, the spa retainer moved in flight, found on pre-flight, has been glassed into place top and bottom to avoid repeat, also fin retaining rod pulled out on assembling to fuse, these are NOT a big deal IF YOU FIND THEM IN TIME! its a great flying model but check it carefully before each start!
