Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
irvine 53 vrs os 50 ?
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 08-10-2006, 06:43 PM
bkelly
Default irvine 53 vrs os 50 ?
im looking to set up another 40 sized profile , so is the new irvine 53 (not made in england?) still a good choice or should a person concider os50 , or say the cheaper super tiger 51?????.....just looking to try something different ..i have the os 46/tower pipe , ys 63, and the saito 82, but always fall back on my mojo with the 46............if the modern irvine is still a good choice, where would i get one .....thanks ...jeff
Old 08-10-2006, 08:26 PM
JPMacG
Default RE: irvine 53 vrs os 50 ?
Not on your list, but I suggest the Enya 50SS. It is lighter and less expensive than the OS 50SX. I'm running one on my Burrito and it gives lots of power for pulling out of a hover. They are ringed with a steel (meehanite?) sleeve, so they will last a long time.
Old 08-10-2006, 09:27 PM
YNOT
YNOT's Avatar
I went with a Webra 50. Stooopid power. Drag raced a Mojo with a Satio 82 and it was a tie.
With a APC 12.25-3.75 you have to work the throttle a bit in a hover or you can do some throttle curve. With a APC 13-4W real easy to hover, however you give up some pop out power. You still have plenty of power.
If you want to go different If I were to buy a new 50 size motor I would do the new OS 50 Hyper. Put an Ultra Thrust muffler on it WOO HOOO, however the bearing will last a short time. Drop some Boca's in it and it would be pretty trick.
Old 08-10-2006, 09:45 PM
bkelly
a os 5o hyper...never herd of it.....its not on os's website.....????.........................unlkess u mean the heli motor....can u do that?????????
Old 08-11-2006, 11:10 AM
fun_fly_3D
thats what he means. yes you can do it but it is called a heli engine for a reason.
Old 08-11-2006, 09:34 PM
YNOT
YNOT's Avatar
http://www.osengines.com/engines/osmg1951.html
Check out that puppy!
Yea, its a heli motor and for 3D they are what you want. They are designed to run in the mid range. The heat sink will keep it running cool in hovers and 3D stuff.
I have done a couple of OS heli motors on planes and they work great! Except for the bearings.
Old 08-12-2006, 01:18 AM
MOJO65-9or10
With no prop hub how do you get your props on it?
Old 08-12-2006, 02:40 PM
YNOT
YNOT's Avatar
But one for an OS 50.
Old 08-17-2006, 05:38 PM
bkelly
the webra with stuuuupid power sounds cool......definitly different, ihave os, ys, and saito, at my feild (small town iowa) their are only os and magnum, and some super tiger......................ive ran a search on the internet but had no luck looking for a source for the webra 50.........1..who sells them....................2..would a pipe be a good chooce and which one?..........3..what fuel, prop,........not sure if it will go on a fusion or the katana v2,...............thanks for ur input..............
