HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
rotostart with lcg tvp's
Old 08-18-2006, 09:33 AM
blowpopracer
Default rotostart with lcg tvp's
I have the extended(1 1/2") fast lane machine lcg chassis. Now I am told the rotostart will not work due to the engine sitting lower in the chassis. Anyways thinking of buying my buddies RB928 to put in my savage to help power it after the chassis weight gain. Anyone know of a rotostart that will fit on the RB that exits out the side instead of the back? Or for that matter another engine that has a rotostart that exits on the side instead of the back. I did see the one on the link below but my buddy's willing to cut me a deal on the rb. He bought the 928 put it in his buggy found out he couldnt control it on the race track and took it out, so its like new.
http://www.amainhobbies.com/product_...oducts_id/4869
Old 08-18-2006, 11:19 AM
JayC1968
JayC1968's Avatar
Default RE: rotostart with lcg tvp's
I ran a k4.6 using the FLM ext. lcg's with no problem. I did have nova towers too, so that helped not having the cross supports that the plastic do. I also ran a Mach 28 with a Losi Spin starter with them also with no problem.
There always is the Tiger Drive that are available for just about every engine out there too. They are the same hex type shaft as the losi
Old 08-18-2006, 12:51 PM
46u
46u's Avatar
It all depends on what shock towers and bulkheads you have. Here is what HPI says about their LCG chassis.
For the original Savage this set requires the use of a pullstarter engine, engines with Roto Start are not compatible. This set can be used with the Savage X and a pullstarter or Roto Start engine, slight trimming of the Savage X plastic roll hoop is required.
Old 08-18-2006, 01:11 PM
SavageGoZoom
SavageGoZoom's Avatar
I have FLM ext tvps and shock towers and i use roto fine
Old 08-18-2006, 01:47 PM
JayC1968
JayC1968's Avatar
Since the FLM are 1.6 inches extended it makes up for the drop of the engine. What I am saying is that the shaft can be used with the FLM EXT. LCG's because the added length decreasses the angle it has to go in on.
Am I making sense? I'm confusing myself a little...
Old 08-18-2006, 02:05 PM
SavageGoZoom
You the Jay I know? I thaught u got a MGT and sold ur savage[]
Old 08-18-2006, 02:08 PM
JayC1968
JayC1968's Avatar
yep I am SGZ, the MGT is gone now too... I own nothing but XTM now...
Old 08-18-2006, 02:11 PM
JayC1968
JayC1968's Avatar
I just help out on the HPI MT forum since I have so much knowledge of the savage from breaking it so much.... I can tear one down and put it back together blindfolded I think..... I'm not putting them down.... I am just hard on my RC's
SavageGoZoom
ORIGINAL: JayC1968
WHY O WHY!!!
Whats so good about XTM
Old 08-18-2006, 02:15 PM
JayC1968
JayC1968's Avatar
Ask the owner of the last Savage I smashed into ... and that was with my XT Deluxe Buggy..[>:]
Old 08-18-2006, 02:22 PM
aidE
What about the FLM's non extended ones? These: "FLM 4.7mm Low CG TVPs" - "Will not work with Rotosart requires modification". What kind of modifications do they mean? I tried mailing Fastlane to get some answers but with no luck (haven't recieved a mail yet).
Im kind of new to this, bought my savage x this monday. I just know that with a extended tvp the truck gets a wider turning radius and that must be considered as something negativly. Then on the other hand what are the pros with having extended tvp's?
Reference:
[link=http://www.smfstore.com/product_info.php?cPath=31_183_204&products_id=860]www.smfstore.com/product_info.php?cPath=31_183_204&products_id=860[/link]
Old 08-18-2006, 02:24 PM
SavageGoZoom
aid E,
That usualy means demaling the towers or the bulkheads to get it to fit or using a difrent started system
Jay... My buggy will kill ur buggy... head on colision i will drive away
Old 08-18-2006, 02:28 PM
JayC1968
JayC1968's Avatar
ORIGINAL: aidE
Reference:
The only way you may get those to work is by grinding away the plastic around the joint post and the joint post itself. I had to do the same thing when I dropped a Mach 28 with a losi roto plate in my HPI LCG's before I went FLM...
I can post a pic of the mod if you need one...........LMK
Old 08-18-2006, 02:33 PM
JayC1968
JayC1968's Avatar
It's all pros aidE.... It does not make your turning that much wider... if you want you can use lighter diff oil to make up for it, or shave your knuckles....
I would and have gave up a few extra inches in turn radius for a 100% more stable and better handling truck anyday
OK.... Nick... put your ego away...
Old 08-18-2006, 02:36 PM
SavageGoZoom
ORIGINAL: JayC1968
You wanna battle my Mugen MBX-5 prospec
Old 08-18-2006, 02:38 PM
JayC1968
JayC1968's Avatar
ORIGINAL: SavageGoZoom
ORIGINAL: JayC1968
I beat one last week...
Old 08-18-2006, 02:44 PM
SavageGoZoom
I gots da mad skillz thow [sm=bananahead.gif]
bring it on haha
[sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif]
Old 08-18-2006, 08:59 PM
SAVAGEJIM
SAVAGEJIM's Avatar
bring it on haha
Where did you get the red smiley gifs? Are there any more animated smiley gifs and where can I find them?
Old 08-18-2006, 10:26 PM
JayC1968
JayC1968's Avatar
ORIGINAL: SAVAGEJIM
bring it on haha
Cick on MORE SMILEYS [sm=spinnyeyes.gif]
When in reply
Old 08-18-2006, 10:29 PM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
on my X with Chronic's LCG plates, I can rotostart my Savage just fine.
All i need to do is NOT put the starter shaft THROUGH the rear bumper, but above it, and go through the same hole in the rear shock tower that you normally do to get to the rotostart.
Old 08-18-2006, 10:33 PM
JayC1968
JayC1968's Avatar
ORIGINAL: ThunderbirdJunkie
Thanks for verifying that TBJ....... There are alot of people that say no........ I know I did.............. TC Bro
Old 08-18-2006, 11:27 PM
ThunderbirdJunkie
word brah
and LMFAO@that pic
Old 08-18-2006, 11:36 PM
JayC1968
JayC1968's Avatar
word brah
and LMFAO@that pic
OFF TOPIC:
I thought you would TBJ.........
I WAS NOT OUT OFFEND PEOPLE, get to know me and perhaps you may find out I did 8 years NJ State DOC.
Old 08-19-2006, 12:33 AM
46u
46u's Avatar
If people go to HPI web site or read what I posted then they would know the whole story! Some people! [sm=tongue_smile.gif]
Old 08-19-2006, 01:35 AM
ThunderbirdJunkie
ON TOPIC
Won't matter soon, I won't be using a rotostart next time i fire my savvy. I got this beauty now
