Threaded Hinges
RE: Threaded Hinges
Here you go. http://www.iroquois.free-online.co.uk/knot.htm
Scroll sown to close sewn hinge. I use this kind made out of dental floss. I have never had one fail.
RE: Threaded Hinges
The "close sewn" hinge looks pretty interesting for small planes, but the drawing on the link left a bit to be desired. Does anyone have a better illustration of the wrap pattern?
Tom
Tom
RE: Threaded Hinges
The close sewn hinge is a figure 8 hinge laterally compressed. You make slits in the stab and elevator, also notch the leading edge of the elevator to clear the hinge at the centerline. Do put clamps on the pieces to hold them in place, or you can pull them out of line while sewing. I use dental floss and a needle to sew with. I start by poking the needle through one slit and running it back through the centerline and through the tied end of the dental floss loop. I pull it tight and put a tiny drop of CA on the floss to hold it in place, and then cut the loop knot off. Then sew away in a figure 8 fashion with the crossover at the hinge centerline. Be neat, pull everything tight, and, when finished, use a drop of CA to fix the end, then cut off the excess. I generally fill the slits with Sigment. I've used these hinges on up to 40 size CL airplanes and never had a failure. If one starts to fail, you could see it, I suppose, and replace it.
ON, CANADA
RE: Threaded Hinges
Hi All,
I find Figure 8 sewn hinges light, very flexible, easy to do and cheap.
I made a template to space 5 holes about 3/32 apart. I drill through with a 1/32 bit in a hand mandrel.(10 holes per hinge)
I use polyester thread. I cut off 2ft. or so and tape it to the bench with the end of the thread hanging over. I put a clothespeg on the end to make it hang down straight. I then coat the thread 2-3in. above the peg with CA. This makes 'a needle' from the thread which works great. It is easier than threading a needle.
I double hinge the area where the control horn is.
Much easier and faster than slotted hinges for me. I like the 'old school' look.
Take care,
Have fun,
Dave'crosscheck'Fallowfield
Maac 6437
Unabashed Combat Team
Take care,
Have fun,
Maac 6437
