Repairing hangar rash on canopy
Old 08-25-2006, 02:34 AM
Olli-Matti
Default Repairing hangar rash on canopy
Hi!
I am wondering how to treat a canopy that has a dimm spot on it? I think the spot has come from canopy rubbing against the shipping boxs´ walls.
I am planning on tinting the canopy and am pretty sure that when I tint the inside of the canopy the dimm spot on the outer
surface will be clearly wisible.
Has anyone had similar problems?
(I know that dimmed canopies are a hard fix, but maybe a clear coat of somekind would work, with a paint that doesn´t melt the canopy)
BR
Olli
Old 08-25-2006, 03:42 AM
Runway
Default RE: Repairing hangar rash on canopy
Have you tried a polishing buff fitted to a modeller's electric drill? Worth a try?
Old 08-25-2006, 09:04 AM
Ugo Ferrari
Ugo Ferrari 's Avatar
Try some toothpaste, on a soft damp cloth and just rub out the fine scratches until it shines again. Rub it until it's dry. Apply again if neccesary.
This method also works on plastic sunglass lenses that are scratched.... It works !!
Ugo
Old 08-25-2006, 11:30 PM
jsn
My Feedback: (8)
Take a look at these kit's https://www.micro-surface.com/defaul...page_id=175#17
I've used the acrylic kit to polish out scratches... that and the polish makes it look like NEW.
John
Old 08-26-2006, 12:54 AM
SMUGator
SMUGator's Avatar
Anyone heard of or used "Weenol"? My father-in-law is an excellent plastic modeler and swears by the stuff for buffing out canopies, but I've never seen or hear of it.
Tom
Old 08-27-2006, 07:52 PM
jsn
My Feedback: (8)
Tom... could be this stuff http://www.wenol.com/ Never used it myself and it seems to only be for metal.
John
Old 08-28-2006, 09:09 PM
Stickbuilder
Stickbuilder's Avatar
You can get auto wenol at most speed shops and stores that carry better grades of aluminum wheels. It is a high grade low cut aluminum polish (very much like semi-chrome) or some of the metal polishes that are impregnated into a wadding material. You might also try your local Harley shop. Another thing that will work is to use Mother's polish ( about the same results) Do not use a speed wheel to apply and buff the canopy. You will go through it when using one of these polishing compounds. Toothpaste is still one of the best for good results. You could purchase a plastic polish that Harley Davidson shops sell for cleaning the scratches on windshields. There are any number of products that will return the results that you are looking for. The secret is to go slowly, and not rush things. Using water on the cloth that you are posishing with will reduce the likelyhood that you will burn through the canopy.
Bill, AMA 4720
Old 08-29-2006, 12:12 AM
SMUGator
SMUGator's Avatar
I'll probably grab some of this stuff just to play with. Seems like it could have many modeling and household uses.
Tom
Old 09-08-2006, 02:01 AM
Olli-Matti
Ugo
Big thanks for the tip Ugo, it really did work! [sm=biggrin.gif]
I recommend everyone to try it out as well.
-Olli-
Old 09-08-2006, 09:22 AM
Ugo Ferrari
You are quite welcome Olli !! I always say," Keep It Simple".
Ugo
Old 09-11-2006, 01:28 AM
CafeenMan
A polishing kit (follow the directions) and plenty of elbow grease will make the canopy better than when it was new. You can get polishing kits from micro-mark.
