xtm 457 problem
xtm 457 problem
i just got a new xtm 457, i did 3 tanks heat cycle, but now i cant make the engine run right, after 2-3 mints running the engine will bog after you bush the throtel, it will accelerate build speed for a few second then it bog, i tried to adjust the high speed nv its almost 4 turn open without any sucsses, itried to adjust the low needle and agian did not make a diffreence, in generla the needles did not seems to change it at all, any idea? am using aluminum clutch shoes by sportwerks, and 1 mm springs, i cheked the trani and looks ok, am not sure what to do anymore? help
thanks
thanks
NC
RE: xtm 457 problem
Stop what you are doing right now and seal the engine. The last thing you want to do is let a simple little airleak totally screw up the break in of that engine... and it WILL, if that's the problem.
NC
RE: xtm 457 problem
I thought I read something about high engine temps when I looked at this before... guess not
yeah, could be something as simple as the glow plug like xtremeraptor said.
