Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
Wooden Blades for 36
Old 09-01-2006, 09:45 AM
higgy1541
Default Wooden Blades for 36
I have just purchased some wooden blades for my 36. I got them from HeliDirect, you can see the blades [link=http://www.helidirect.com/product_info.php?products_id=578]here[/link] . I have just recieved them and they have got a white plastic covering on them. Does the whole white film need to be peeled off or do you just need to make a whole for the bolt to go through?
James
Old 09-01-2006, 09:55 AM
sweetrevenge7800GTX
Default RE: Wooden Blades for 36
The whole film needs to be removed.
Old 09-01-2006, 09:57 AM
higgy1541
Ok thanks, Just didnt want to go ripping it all off to find out i ruined a set of blades.
Old 09-01-2006, 01:38 PM
E_Heli
Don't rip it off, they used to use clear covering and I have couple set from them. Now they use the white covering, I would check the balance first, and check the tracking afterward.
Old 09-01-2006, 02:47 PM
higgy1541
ummmm, little bit late. I took the covering off one set. Does anyone else have experience with these blades?
Old 09-01-2006, 04:40 PM
Orion1024
Orion1024's Avatar
Leave the plastic on - the blades are supposed to be covered. These blades work very nicely. However, they were a little too long inside the blade holder, so I had to remove some off the end with a Dremel. You should be able to cover them back up with the correct size shrink tubing.
Old 09-01-2006, 04:44 PM
higgy1541
I was thinking about just giving the blades with the stripped off covering a coat of clear lacquer.
Old 09-01-2006, 07:54 PM
sweetrevenge7800GTX
i ripped mine off and they worked just fine
Old 09-02-2006, 12:24 AM
higgy1541
ORIGINAL: sweetrevenge7800GTX
So the blades have no covering, they are just the bare wood?
Old 09-02-2006, 06:05 AM
sweetrevenge7800GTX
Yeah basicaly. but the work Very Well.
Old 09-02-2006, 02:55 PM
neweheliflyer
For No. 36 helicopter, [link=http://www.hobbyjapan2000.com/store/proddetail.php?prod=PlastMBaldes]this kind of blades are good - very durable[/link].
