SAVAGE X THROTTLE PROBLEM!!!!!!!!!!!
hi i got a savage x about a week and a half ago and i was runnin it to day but suddenly the control wasnt workin so i turned the engine off and pressed the throttle but the carb seemed to be opening up a tiny bit when the throttle was depressed.I think it could be the throttle servo but im not sure. plz help!!!!!!!!!!!!!!!!!!!!!!!!
RE: SAVAGE X THROTTLE PROBLEM!!!!!!!!!!!
First you should check the TH-TRIM on your controler, then see if the carb slide's easly on its own. I have the savage .25 and it wouldent give me full throttle so i made my own gass ,brake setup. Now ive got full throttle and bad a** stock brakes that i can adjust for more or less on eather.
The first thing to check is that all the batterys are fresh/fully charged. Then, and only then, start looking for mechanical / equipment problems.
the batteries are new and the throttle linkage seems 2 be ok as i was runnnin it be 4 and nothin was wrong.it just happened so sudden.
WV
If the problem is the servo. Get a new steering servo and move the stock one to the throttle. This is one of the first upgrades a Savage needs other than aluminum clutch and tuned pipe.
ORIGINAL: steve9000
could the problem be the servo???????????????/
hope this helps let us know how u got on
ON, CANADA
hello, im having some problems with my savage x.. when ever i give it gas the breaks go on please someone help..
WI
Savage x driver do you have a switch on your controller that allows you to reverse the throttle contol? If it does reverse it if not I dont know how to change it.
