Pull the sleeve out
Old 09-16-2006, 11:32 AM
2fast2slow
Default Pull the sleeve out
Wassup,I just got a new motor and i had a couple problems with it and mistakenly i put the sleeve in wrong so now half of my intake and exhaust ports are closed off because i didnt line it upright when i put it back in and now i cant take out so does anyone know how to remove the sleeve so i can line it up right
Old 09-16-2006, 01:19 PM
teamrayman
teamrayman's Avatar
Default RE: Pull the sleeve out
try pulling the starter...the piston should move it up
Old 09-16-2006, 04:51 PM
WalawalaStore
Hi,
There should be a little stud on the engine case making sure you have the cylinder facing the right side. Doesn't your engine have that?
You can turn the crankshaft (normal direction it would turn) and the piston will push the cylinder up, once it is up, hold it with a flathead screwdriver, then turn the crankshaft in reverse direction until the binding is gone.
Thx
Joaquim
