T-Maxx Problem
PA
T-Maxx Problem
Hi I got a t-maxx 3.3 and it runs good but the idle won't go down it seems to be pulling air from some place but were could it be pulling air from?
RE: T-Maxx Problem
The idle not dropping is usually a symptom of an correctly set LSN, idle screw, linkage or trim adjustment on the transmitter. If it were an air leak you would have tuning and overheating issues too. If you're intent on looking for an air leak the most common culprets are the backplate and the carb throat with bearings and carb needles coming next or possably a leak in the exhaust/fuel system.
