Prepping a Carbon Fiber Chassis
Old 10-03-2006, 08:07 PM
co_alpine
My Feedback: (35)
Default Prepping a Carbon Fiber Chassis
I am doing my first CF chassis build up and I remember people in the past that talked about prepping their chassis. I think they did some sanding on the edges and gluing on the edges. Can someone talk about this, why and how you would do it.
thanks,
Old 10-04-2006, 07:48 AM
snowbl!nd
snowbl!nd's Avatar
Default RE: Prepping a Carbon Fiber Chassis
I've never done it, but i hear you lightly sand the edges of the CF, and then run a bead of superglue around the edge to prevent it from splitting. I've got a CF radio plate and CF shock towers for my onroad nitro in the post, so i'll probably go that route.
Old 10-04-2006, 08:04 AM
bozla
bozla's Avatar
Remember that carbon fibre is a laminated material. You'll want to glue the edges to prevent it from delaminating.
Old 10-04-2006, 02:35 PM
AWDrift
yup... u guys are correct. unless u purchase vantage products, where the edges are sealed.
Old 10-05-2006, 01:33 AM
WalawalaStore
Hi,
Carbon fibre dust is toxic material, it is suggested that you use water type sand paper (don't know the correct name), no.600 - no.800 is fine. Make sure dust don't fly around. You should also wear gloves and goggles. Sand out the sharp edges and wash it with soap or detergent. Wait for it to dry and use cotton tip to apply CA glue on all edges.
Regards
Joaquim
Old 10-05-2006, 07:27 AM
co_alpine
My Feedback: (35)
that is good to know, thank you for pointing that one out.
Old 10-05-2006, 03:39 PM
46u
46u's Avatar
I CA glue all my CF edges! I use a Q-tip as and applicator and works great.
Old 10-05-2006, 08:40 PM
hands without shadows
hands without shadows's Avatar
Isnt cotton like a CA accelerant?
Old 10-05-2006, 09:19 PM
46u
46u's Avatar
Not from what I have found matter of fact the cotton part takes longer to dry not faster. I dip the whole end in the bottle when I seal the edges of CF parts.
Old 10-06-2006, 03:00 AM
WalawalaStore
ORIGINAL: 46u
Hi,
It will work better with cotton tips that has wooden sticks. Plastic sticks could be burnt by CA and generate a smoke but no big problems.
Regards
Joaquim
Old 10-06-2006, 08:40 AM
mattnin
mattnin's Avatar
After you prep it and then it happens to splinter later due to a crash or whatever, just sand the edges and re-apply the CA glue. Keep your CF chassis healthy!
