i need help with a magnum motro
i have a 4 cycle 52 magnum, mounyed upside down on a hanger 9 pulse. i can't mannage to get to idle. plus the idle screw is a little bit lose, i htink that it could be absorbing air thru it. i appreciate any advice THANK YOU
My Feedback: (58)
VA
RE: i need help with a magnum motro
Mandoaulet, If you are running it rich you may be drowning the glow plug. You might try a on-board glow driver to keep the plug hot. Might try to lean the low end a little. I try to mount my glow enjgines at 90 degrees or side ways. Wayne M.
