My Brother Builds the Ultimate Trailer
I just had to post one pic of this trailer in a separate post, sorry. I have looked at all the trailers in the ultimate trailer post and have to agree they are all fantastic. But since this is my brother and I have a personal attachment, I just have to show it off for him a little
He scratch built all the adjustable fuselage hangers - very very nice job.
Receivers all have there own little home behind a hinged lid with a plexi front.
The largest plane (so far) will go in the spot under the wings on the floor.
Two trickle chargers - one for the planes, one for the Tx's.
These are wired up to an all weather external 110 jack.
Radio Shack remote temp alarm - wired to go off in the house.
Heater and of course over head lights.
He will be able to go fly, clean everything up, put the planes and Tx's to bed, plug them all in, go home and park the trailer, and plug everything in at one time. Wake up refreshed and go fly
He's in the middle of the trickle charger conduit runs now.
Plans to mount a spare props rack, field box and fuel holders, etc., etc.
I AM SO JEALOUS
I AM SO JEALOUS
My God Man!! That is an incredible trailer, I really like the fact that you can charge everything with just 1 plug. Truly amazing!
Allan
Allan
Thanks Guys - I'm sure my brother will
be pleased with your comments Now that I have it posted I guess I better let him know what I did
I'll see if he will respond to your question Bob.
Right now I own a Jeep Cherokee and, needless to say, it gets pretty full of stuff when I go to the field. I've been considering a trailer but I'm concerned with just hanging things on the walls. What about all those bumps and pot holes?? Don't things really get jostled around in there? How is everything held in place?
I informed my Brother that I had
posted a picture of his trailer, and it seemed like a few people were kind of interested in it
He said he will try to get on RCU this weekend and try to answer any questions posted and may even have a few new pics.
I took the one I posted at Xmas, so he's had a little bit of time to work on it since.
He is one busy dude
Vacinekm - Once everything is done, there will be some very soft hold downs for the wings and fuselages installed. They keep everything snug against the foam padding, so it's a pretty smooth ride for everything. He has something special in mind for holding the Tx's down.
Later
By the way, there are a few more pictures of it posted on my RC Home Page for those interested
He is one busy dude
Later
Building the Trailer
Hi Guys, Thanks to my brother for all the kind comments about my trailer... and to the rest of you as well.
The trailer is a 6x10 Wells Cargo ToteSport with optional rear corner stabilizing jacks (a must-have option if you have the choice). The system that I made to hold the wings and fuselages is designed to be modular and adjustable to a variety of sizes of planes. I screwed horizonatal runners to the side walls of the trailer (into the metal vertical studs - 16" centers) first. These runners are screwed into place at identical spacings on each wall. Each runner has t-nuts inserted from the rear every four inches. Uprights are then screwed to the horizontal runners (via the t-nuts). I used the large, hex-head screws that you see used for Scandanavian furniture to hold everything together... the head size is about 5/8" diameter (only 3/32" thick) and provides a lot of clamping force so nothing comes loose. The uprights for the wings are drilled every 4" for dowels... this lets me move the dowels around to accommodate different wing sizes.
The fuselage hangers are attached to the same horizontal runners as what I did for the wings. I'll have to take some pics to show how the fuselage hangers work.. they can be adjusted horzizontally or vertically on a 4" grid, and can be slid toward, or away from, the side wall to account for different size tail feathers, or for fixed nose gears . Since the spacing on all runners and uprights are the same I can move wings or fuselages anywhere within the trailer just by unbolting uprights and moving them around.
To keep things from bouncing off of the racks I'm simply using 2" strips of felt fabric, and tying each airplane part to its location... I might come up with something else a little later on.
I installed the 110 V wiring using all 'nema' rated, waterproof housings (pretty pricey, but I didn't want to risk injuring anyone due to faulty wiring, etc.). I've got the transmitter wiring completed... now working on conduit to carry charge power over to fuselages... should be completed tomorrow. Once power strip (above transmitters) is wired constant current, second power strip is wired through TME trickle adapter. A Hobbico cycler is on the shelf above the transmitters... this way I can continually trickle some plane/radio combinations, constant charge others, and do specialty charging via the Hobbico.
Still have to build hold-downs for field boxes, mount a fuel carrier, and build a prop rack and misc. spare parts bin.
It's really been a lot of work.. making jigs to router out everything, etc. but I'm going to so enjoy not tearing up airplanes carrying them up and down the narrow stairwell of our home!! I better get it done quick.... Spring will be here before I know it!!
Thanks again for the kind comments...
...Rob
...Rob
making some progress
Finally had some time to get back to finishing up some things on the trailer. The transmitter rack is now complete... as is the prop rack.
Will try attaching some photos here...
another photo
Tried attaching multiple photos but that didn't work... here is one of the prop rack.
Charging rack in previous photo is set up so that (6) wall chargers can be plugged in at once and all trickle through a TME cycler feeding the power strip. The cords on the wall chargers are long enough to plug into the second power strip which is hooked up for constant charging. Each wall charger feeds (1) plane's transmitter and receiver. This way, all the planes and all the transmitters are charged in place and I just plug the trailer in when I get home.
The Hobbico AccuCycler is used to custom charge non-standard battery packs and I ran cables that are long enough to reach any fuselage or any of the transmitters.
Has been working great for the past couple of weeks, and as a bonus I've managed not to burn anything down!
another pic
This one shows the entire charging set up. Next time I would try to buy charge strips where all outlets were in a single line... that way I could mount one high, one low and then just plug chargers into upper or lower outlet strip... would make the wiring much neater. But, these new Stanley power strips did look kind of neat so just decided to go ahead with them.
final pic
I built these two spring-loaded, pull-to-release latches to make sure the door couldn't fly open and send the transmitters on a wild ride. All of the wood that I cut and put together is held together by screws and glue so that it can't (fingers crossed) vibrate apart during trips.
If anyone is interested in pictures on how to do some of this stuff, please just let me know and I can provide some detail pics... may take me a couple of days to get to it, but I promise I'll get it done for you.
another pic
More Pictures Posted on - Putt's RC Home Page
My brother has posted more pictures of the trailer on my Home Page link below for those interested.
If you have trouble viewing my site, please let me know. If you do visit, please take a moment to sign the guest book and let me know what I can do to improve it.
WHOLLY TRAILER! I think I could live in that thing. Where is the unsanded bare plywood? Where are the bent/ broken nails you just hammer to the side when you tweek one putting it in? Where is the...... nevermind, I don't think we'd find it in your trailer. :-)
Very, very nice!
Very, very nice!
WV
That is one bad-ass trailer my friend. Excellent work. Now if I only had more planes, more money, more time, and more energy I'd try to duplicate yours
The subject title was miss leading but nice job. After reading the subject " **Builds the Ultimate Trailer" led me to believe that another trailer had been built, like how I built mine from scratch. Turned out to be just a custom interior job.
As I said nice job though.
