HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
ANTENA WIRE
Old 10-25-2006, 02:02 PM
magictrev
Default ANTENA WIRE
My antena wire just broke on my new savage x in the middle. The hobby store said i cant buy just the wire and I cant use regular copper wire? They said I need to solder the old wire or buy a new reciever for 60bucks. Can I not just use regular copper wire if the length and guage is the same?
Trev
Old 10-25-2006, 02:44 PM
Gravrober
Gravrober's Avatar
Default RE: ANTENA WIRE
yes you can. I think someone is trying to make some money off you...*******s.
Old 10-25-2006, 04:04 PM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
LMAO@your lhs.
Futaba sells receiver antenna wire, your LHS sucks.
http://www2.towerhobbies.com/cgi-bin...&I=LXH356&P=ML
in fact, I bought it from MY lhs. but no, using regular wire is not recommended.
Old 10-25-2006, 05:27 PM
-SomeGuy-
-SomeGuy-'s Avatar
Yeah as far as i know you shouldnt use solid copper wire, the antenea wire is a bunch of smaller wires. Im not sure what the reasons are for not using solid wire but knowing not to use it is good enough for me.
Old 10-25-2006, 06:21 PM
magictrev
WOW thanx for the link to tower. I told my hobby store someone must sell the wire, and they said nowhere, and if you could find it, it would be big bucks. I will order from tower
trev
Old 10-25-2006, 06:23 PM
magictrev
it says futaba wire and I have the strock HPI radio that came with my savage does that matter or will the futaba wire work?
trev
Old 10-25-2006, 06:49 PM
Nathan9492
Nathan9492's Avatar
the futaba wire will work...
Old 10-25-2006, 06:55 PM
DaveG55
DaveG55's Avatar
ORIGINAL: magictrev
trev
Yes, it will work just fine.
Can you solder? You'll need to take your reciever apart, unsolder the existing wire and resolder the new one in. It will be jut like new - as long as you can solder that is.
For the record, The antenna wire is copper. It's just stranded copper not one solid wire. The reason that you don't use a solid wire is that a single wire is too brittle and would break easily.
Old 10-25-2006, 06:58 PM
fxrs
fxrs's Avatar
Hey magictrev
After you get the wire in the mail, take it down to your
local hobby shop and show it to them. Show them the
receipt also, then tell them to kiss your *****.
Now if you like your LHS then don't do that. I have a good hobby
shop here in NJ that I go to.
Old 10-25-2006, 08:30 PM
ThunderbirdJunkie
ORIGINAL: magictrev
trev
your LHS sounds shady. tell them you can order the wire from them or Tower, doesn't matter to you. They might straighten up and fly right.
the Futaba wire is fine, i use it in my Novak AND futaba receivers with great success
good luck man, and get yourself a soldering iron...the grand total should be around $15, which is FAR cheaper than the receiver
BTW-measure both your remaining pieces of wire and cut one of the same length from the wire i linked you to. there should be enough wire there to make 2 antennas
Old 10-25-2006, 10:29 PM
46u
46u's Avatar
I only had this problem one time and went to my local electronics store with the piece of wire that broke off. They matched it up with a piece of scrap they had and gave it to me for free. Worked just fine till I change radio systems.
