RCM drives
Im looking to purchase an rcm drive for a expresscraft thunderbolt . ive seen some on boat pictures around (xxxboatworks (nice stuff)) im curious on some of the specs height length weight etc. any help would be appreciated.
The boat is 50" long and 17" wide. The RCM drive will fit on the back, but you need to do a small amount of grinding to make it fit. If you decide to get the hull (and drive) from me, I can mount the drive for you if you are not comfortable in hacking on your new hull. It makes for a very good looking combo.
i just need the drive. How much are they ? do they look scale on the back of the thunderbolt? how does the boat preform with it on? stock 260. Are they heavy? thanks for help it is much appreciated.
The drives are around 225. It looks very scale on the boat and it will handle/perform well. If you are looking for max speed, I would suggest you go with a regular drive/rudder. I will find a pic for you and post it.
