Fuji BT43EI good as a first gas engine?
Hi.
I am planning on buying the 25% Greatplanes YAK ARF and installing a Fuji BT43EI.
Is this a good engine?
Can i see some pics of your installation?
Also,
when you mix gasoline with oil,
you just drop the oil in the can with the gasoline and then shake the can?
Also,
My Feedback: (40)
RE: Fuji BT43EI good as a first gas engine?
Hi
Normally it's easiest to pour in the oil and just fill it up with gas. It's just like making the gas for a boat, lawn mower, or chainsaw.
As far as the engine choice.. well that directly relates to the type of flying you wish to do. Personally for similar money, lighter engine, and more power I would put a Brillelli 46 in it. http://brillelli.com/brillelli_engines_009.htm
I think will be happier as your flying develops and you need more power.
Just my 2 cents.
Just my 2 cents.
DC
I was staying away on purpose, the comment was "how come I knew Sinergy would reply to this with a plug for Brillelli" and "Hey Poco, do you pay this guy to slip your link in after every question about a 40 something engine" ..Congrats, now you know...Happy now ?
My Feedback: (40)
I think you know that the same way I know, every thread that involves a 50 or 60cc engine comes from you a price drop of 440 and a speed of 190mph
It's not my fault the Brillelli is a great engine, is a great price, and is a better choice then the one being discussed when I speak up. I am only trying to be helpful with what I believe to be facts.
All you are doing with your now famous "." is removing your comments that only make you look bad. I am sorry there is a company out there that threatens you, but truth be known I am only being helpful. I am not being paid to share quality recommendations.. I am simply trying to help.
I am sure somewhere outside of your ego you can see that my recommendation to consider a Brillelli 46 over a Fuji 43 is wise suggestion.
You might want to look for a thread about the new WH Extra and a G-62... you may notice that I recommend it get sent to you first. Which once again was only a helpful recommendation in my mind.
My Feedback: (61)
I purchased a Fuji 43 EI as a first gas engine and installed it on a G.P. Ultimate 1.60, I had lots of RFI issues but finally got it resolved by moving the ground wire direct to base of spark plug... I will add that others used this engine on the same plane without any problems... The engine is turning an MSC 20x8 prop at 6500 with about 1 gallon of gas run through it... The engine is very smooth running, it has no more vibration than my 1.50 and 1.80 Saito's... The engine starts very easy and has been reliable and idles very slow... I am happy with it but will add that I wish it had a little more power... Mine weighs 3.75 lbs with ignition... Just a comment from a newbie gas user, But I know one thing, I love gas!
My Feedback: (243)
The Fuji BT43EI will be fine, both as an engine alone and for your particular application. It is a reasonably priced, quality built engine.
Any time anyone asks about a particular engine, you will always get responses saying another brand is better or more powerful (all of which are generally more expensive, except for the Brillelli). It is a matter of individual preference so take it as that.
Gas engines need ample break in running to produce maximum power so none should be judged after the first gallon or two. I have Zenoah G-23 that I will absolutely not part with. It took three flying seasons to get eight gallons through it and it is now a snarling monster compared to the first season.
I have a Fuji BT43EI in the box waiting for project time plus a Fuji BT24 (new model) on back order. Specs say it weighs approximately two lbs including muffler so that one may start a new round of who has the lightest 23-26cc!
DC
UHHH...If you will look back a while you will see that there are no more posts from me about $440 or 190 mph...The two don't go together anyway...There is no company out there that threatens me, I can't keep up with what is in the shop now....I sometimes react to things and then have a change of heart...If the powers that be here would change the way posts are deleted so that EVERYTHING including the name is removed there would be no "." problem....
You're as bad with Brillelli as I am with Zenoah, maybe we should both back off a little..
ORIGINAL: Dick T.
hamman Date 11/6/2006 12:40:52 PM
Am,
can i see some pictures of your engine?
Also,
why did you installed the ground wire directly to the base of the spark plug?
Also,
i saw that Fuji(On Tower) has a 2stroke oil exactly for Fuji engines.
But the cost is really high,isn't it?
What other choices do i have considering the lubricant?
Thank you all guys who replied to my post.
You know,
buying an engine that's not a glow engine seems at first weird!!!!!!
Kostas
My Feedback: (40)
ORIGINAL: RCIGN1
My recommendation is a solid one and I am sticking to it. Almost 1/2 pound lighter and will spin at 22x8 at 6600 rpm new verses the Fuji in question spinning a 20x8 at 6500. Prices very close... seems like a no brainer to me.
As far as me toning down my recommendations.. can't see that happening. It's an awesome product and the price is right.
My Feedback: (40)
well I orig. suggested he 46.
I think a 40 is a bit small for that plane. I had a WH Yak with a strong 44 on it and it was great till you tried anything 3D and it wouldn't do much. I know that engine was stronger than a 40 and since the planes are similare weights I opt'd for the 46 choice right from the get go.
My Feedback: (243)
ORIGINAL: Silversurfer
Fuji is a line of engines best known for being cheap. With the exception of a certain B-25 that has a couple of cherry picked engines that's about their only claim to fame.
Your statement "Fuji is a line of engines best known for being cheap" without facts is a pretty lame instead of saying it is your personal opinion. Sure some Fuji owners have had a bad apple but so has DA, 3W, ZDZ, and probably even Brillelli has had an occasional clunker.
If you don't own one then say it is your personal opinion or button up. Kostas1 question is about the Fuji43, not everyone's pet gas burner.
RCIGN1, your comments are always appreciated. You are one of the rare folks on RCU who know what he is talking about...walking the walk rather than talking the talk.
Kostas1,.
I tend to agree with Silversurfer, but why don't you do a search on the Fugi 43cc and read what other owners have said.
Bruce
Bruce
NC
I guess since I own a 43 fuji I can chime in without getting jumped on. I have one on a GP Ultimate. It flies the Ulti nice but that is for the type of flying I do. It is not a 3d machine with this engine. I have a 21x8 PT CF prop. I do like this engine it is very reliable engine and a excellent bargain when purchased from tower with the discount they give you. As a first gas engine I cant see why not. Check the Yak thread, I am sure someone used this combo and can comment on the performance.
My Feedback: (243)
ORIGINAL: cu. in.
Kostas1,.
Bruce
Kostas1,.
Bruce
My Feedback: (243)
Thank you for hands on comments.
The thing that some fellows miss when chiming in about their pet gasser is not everyone wants a 3D engine! That is not a benchmark for all engines.
Comparing a Brillelli 46 to a Fuji 43EI is fair based on real performance, weight, cost, etc., not "known for being cheap".
My Feedback: (61)
Kostas,
Here is Fuji mounted on a G.P. Ultimate. Flew 60 oz gas through it this afternoon, it runs nice and reliable as I previously posted... The plane weighs 15 lb, will hover but very slow pullout... Its not for hardcore 3D in this plane, but I really like the engine... Im not that interested in 3D anyway...Top veiw shows the mounting of ignition battery, exhaust side the E.I.M and SmartFly ignition cutoff under the EIM, and before everyone jumps on me the screws that hold the EIM in place are run through fuel line for isolation... carb side shows nyrod throttle linkage and choke rod runs out front of cowl... The fuel tank mounted on CG... Receiver and its battery are mounted under front edge of canopy, with servo for throttle to right of receiver... Hope this helps....Larry
Thank you for your pics.
Ah,
i have some questions though!
What type ( diameter ) fuel line did you use and also did you use the same fuel line for the installation of the inside of the tank?
Also,
what prop do you use?
Ah,
Also,
Kosta,
Kalispera! I too have a Fuji 43EI mounted on a GP Ultimate and find that this engine is as user friendly as my DA50 and DA100. Not as powerful as perhaps a ZDZ40, but at least you can rely that it will start without throwing out your arm. My engine has provided excellent service in the last year. I have had no sudden dead sticks, no interference problems and I can fly the Ultimate 12 -14 minutes safely on a 16 oz. tank (with a few oz. to spare). It was broken in on Lawnboy ashless oil (petroleum based oil) at a 32:1 mix for a gallon. I am now using AMSOIL synthetic at an 80:1 mix. I ran this mix all summer in the Arizona heat without a problem. Currently, it sports a XOAR 20X8 prop and it consistently does 6600 RPM. I am thinking of swapping it out for a Mezjlik CF prop to squeeze a few more RPM out of her. I would say that the Fuji 43 is a good value and will provide good reliable service. It will perform well in aerobatic airframes at 14lbs or less (12 to 13lbs if you want stellar 3D performance). If you desire power, get the ZDZ40, however, prepare yourself for many frustrating days of attempting to start the beast. I have read much positive hype on the Brellilli, however, I do not know anyone in my club who currently is using one, so, I can't comment on it's performance. I think for a first gasser the Fuji is an excellent engine. Feel free to contact me if you need any more information on this engine (from one fellow Greek to another).
Yea sou!
Antones Meologos
Yea sou!
Antones Meologos
