Fuel injector blockage
Old 11-24-2006, 06:29 AM
shorty55
Default Fuel injector blockage
How can you clean/unblock fuel injectors? Is there a liquid you can submerge the fuel ring into or is it a case of "prodding" out the needles with a very very thin piece of wire?
Thanks.
Old 11-24-2006, 06:33 AM
Miniflyer
Default RE: Fuel injector blockage
Use water, and suck it throgh the needles and out where fuel usually comes in with a high volume pump (kavan fuel pump e.g.). So flush it in reverse :-). You can also use fuel if you wish....it is just important not to flush it in the direction of fuel flow, but against it.
best regards
Hank
Old 11-24-2006, 07:04 AM
David de Botton
Injectors are clean by using an ultrasonic cleaner.
It is a simple process that any automotive injector service centre could perform & it's not that expensive so do it well & do it once.
Cheers
David
Old 11-24-2006, 07:18 AM
shorty55
I think the aussie cricket team could do with putting in an ultrasonic cleaner
Old 11-24-2006, 07:42 AM
jason
jason's Avatar
I did hear that some engine makers pump oxygen in the manifold and then heat it up. Can't remember the full details though.
jason
Old 11-24-2006, 07:52 AM
Spartan Missile
Shorty, i have an ultrasonic cleaner at home.
You anywhere near Coventry ?
Old 11-24-2006, 08:01 AM
shorty55
Fraid not , lancashire.
Old 11-24-2006, 08:09 AM
Falcon 64
Falcon 64's Avatar
Don`t forget the lube restrictor..
This is probably blocked too.
Old 11-24-2006, 08:17 AM
shorty55
Apart from 2 injectors blocked I had another strange event, vapourised fuel coming out of the gas pipe when the engine was running, any ideas why????
Old 11-24-2006, 08:28 AM
Spartan Missile
The gas port should have a non return/check valve/solenoid valve in line with it.
Otherwise you may vent hot stuff !
What is the make & model of your engine ?
