Sport size Petrol
Old 12-02-2006, 11:42 PM
KiteDr
Default Sport size Petrol
[size=4]I am intrested in geting into gas aircraft and are after a sports model. I am a builder at hart al thow i have had arf's. I am a hack piloit i like loy inverted pases and all thoes hoon type of flying. My faverout plaines are ultra sport & ugly stick. any advice on engin size and kit arf or plan. Thank You
Old 12-03-2006, 07:37 AM
pe reivers
Default RE: Sport size Petrol
what size of "sport size" do you have in mind? Span, weight, wing configuration plz.
Old 12-03-2006, 08:20 AM
KiteDr
I was thinking of somthing around 20 to 30cc size. but it is more the plane's perfomance that i am after & if a 60cc model could give me that i will go
Old 12-03-2006, 10:54 AM
pe reivers
The MVVS 1.60 is about the most powerful in class, and can 3D a plane up to 12 lbs if used with tuned pipe. For aerobatics and sports 12 - 15 lbs is fine, with planes in the 70 - 85" span class.
35cc, 45cc and 58cc are all powerhouses, but may be a bit too much.
Old 12-03-2006, 08:51 PM
Flyer Freq
Flyer Freq's Avatar
Check out my Cap X on the following website. The engine size is ideal, for this plane, and the plane is on sale for $249.00 in U S dollars. You can get into gassers for a very reasonable price with this combo. I am just learning its capabilities. So far, I am very impressed. I have utilized the customer service from BCMA, and have found it to be incredible as well.
Andy
http://www.bcmaengines.com/gallery.htm
http://www.chiphyde.com/html/aircraft/capx.html
Old 12-03-2006, 09:09 PM
tkg
First time Gasser then get a Zenoah. if some engine experence (patience too required) then try one of the Chinese engines.
Cant go wrong with an Ugly Stick
Old 12-04-2006, 09:31 PM
andrew66
andrew66's Avatar
ive seen a few fourstar 120s with gas engines. i think there is a few threads here about them.
Old 12-04-2006, 10:03 PM
Flyer Freq
Flyer Freq's Avatar
ORIGINAL: andrew66
A Four Star 1.20 would be a little difficult to set up with a typical gasser, do to the lack of a cowl, and narrow fuselage, but with a little creativity, and an MVVS or Evolution engine, you may get away with it. I am afraid I haven't read any of the threads on setting up the Four Star with a gasser. As far as the plane choice goes, it is an excellent plane. However, if you have advanced flying skills, you may find it to be too close to being like a trainer. Just some thoughts...
Old 12-07-2006, 04:04 PM
KiteDr
Thank every one for there replyies i have been looking around and found the CG wild stick 120.
I think i will get a zonoah G26OPU to start with.
Thank You
Old 12-07-2006, 08:18 PM
tkg
ORIGINAL: KiteDr
Thank You
A bit under powered for wild 3-d stuff, but a very good combo to just have fun with.
