Evo35gt2
WA
Evo35gt2
Anyone running this engine have any feed back they could give? Wondering how it is overall, starting, power, vibration etc....
Thanks for any help,
Randy
Randy
RE: Evo35gt2
Vibrations are OK only a little bit more than the 26, but not so smooth as the 45 (but this engine is a class in its own)
Starting is not as easy as a reed-valve engine. It takes some ten flips to pop and then another ten to start or about.
The 45 starts in 3 flips. A rotary valve as the ZDZ can need even more flips to pop and start.
The new version GT2 has this auto choke version, so the last ten flips from pop to start are not needed. So I expect that your engine will start for the first time when fuel has reached the carb within ten flips.
