best fuel for an RS4 18SS?
NY
Um what would be the best fuel to run the engine of the RS4 3 18SS engine? i was thinking of o'donells racign fuel 20 % ?
i used blue thunder befre but eh i dislike it thanks god the gallon finished already
RE: best fuel for an RS4 18SS?
hey nitro212
you`ll be fine with that fuel.
one thing i found with the 18ss engine is its like to run on the hot side(280F).
i`ve been using the monster 20% for like 2 gallons thur mine without any problems.
NY
ORIGINAL: buggymangp
hey nitro212
hey nitro212
hmm ill try that fuel then since they sell it in my local shop cuz o'donnmels ill have to order it online and they will rip me off with shipping X_x and yeah right now in NY is very cold the engine goes up to like 130 f so yeah
but ill give a shot of that monster 20%
trinity is good stuff, but you will murder your engine running it at 130* f, do you have a body for it? if you do, wrap the heatsink in foil so it gets up at least over 210-220* f
NY
so which one should i get? x_x
http://www2.towerhobbies.com/cgi-bin...p?&I=LXNE22&P=
http://www2.towerhobbies.com/cgi-bin...p?&I=LXMGD7&P=
trinity, but you NEED to get your engine hotter or you can kiss it goodbye fast, dont just lean it out either, you need to wrap it in aluminum foil
NY
ill try that tomorrow after i charge my batteries
*EDIT* i just turn on the engine wrap it up with foil and still just warms up to like 160 F x_x maybe i did not wrap it right? or is beacause is cold outside? uh ill have to test it inside with a normal temp
yeah....dont run the car inside
do you have air holes cut in the windsheild or side windows cut out, if you do, cover them up, also you might have to use more foil to get it warm
NY
but is weird :/ before it used to go up tio like 250 - 280 even tho it was cold now im not sayig is the new pipe maybe i messed up somethign else and not sure what it is but yeah dunno why it dotn warms up now :/ what can it be? fuel? uh the new pipe/header is installed ? unno
