Prop Balancing
Prop Balancing
For years I was using fine sandpaper to lighten one side of a prop in order to balance it. Unfortunately, the airfoil usually becomes deformed using this process.
Recently I was given an easy way to balance parkflyer props and now use it to balance all of my props - even the 18 inch chunks of lumber.
Just put a couple of drops of thin CA on the bottom of the light side and squeege it out to the tip with your finger. Kicker can speed the drying process.
Works like a charm and you don't have to re-seal a wood prop because you didn't sand it.
Jazzy
Jazzy
Prop Balancing
Plane Insane,
I wonder if the Elmer's is a little heavier thus speeding the process of balancing a very-out-of-balance prop.
Have you had any problems with it running or softening when it gets wet?
Do you seal it in any way?
Jazzy
Jazzy
Administrator
My Feedback: (12)
Prop Balancing
Jazzy,
I've used it on props from 8x4 to 12x6, and it is definately heavier than CA. I don't use anything to seal it, and have not noticed any problems with it running or softening. Elmers really isn't a very hard glue to begin with, but it seems to work pretty well for me so far.
Prop Balancing
I've found that the easiest way is to spray the light blade with a light coat of clear Krylon front and back. It drys fast and you can check for balance in about 10 minutes. I gave up sanding several years ago in favor of Krylon. I only use this on wooden props. Test it on a very small portion (like the hub) before you spray to be sure the solvent doesn't attack the original finish.
Ken
Ken
Prop Balancing
Those are very good tips.......(no pun intended). I use Graupner props or Master Screw and I am certain that the CA and Krylon will work on them, but not sure about the Elmers. I also like to have a white tip, or both, so the spinning prop shows it's arc a little better. I balance my props useing fuel proof white paint and paint the light tip front and back. Another forum had a post that he used white out. I found this did not hold up even though I used lacquer thinner to prepare surface for application first. Happy landings.......lownslo
Bob
Bob
Prop Balancing
Painting Tips
I just ask the wifey to check her nail polish basket for white and bright red stuff she doesn't use anymore. Works great when applied quickly and evenly. Good hard stuff and very resistant to the chemicals we use.
Prop Balancing
Lownslo, I just happened to to be in an 'excited pinch' and needed somethin' fast! Good Golly! It works!
And the price! Woohooo! FREE!!!
(Kind of a 'forehead-smacker' huh?)
