for a buddy
AZ
for a buddy
hey guys i got a buddy and he just got a revo and all it needs is a motor? he was wonderin what to get a trx 3.3 a os.18 cvrx, a os. tm, or a ostz, and if its a tz what model. he wants power. but cant spend over $200 and doesnt want a big block? these are his choices ? what would you pick and why? thnaks 4 the in put and i'll let him know.
AZ
RE: for a buddy
this is the 1 he was lookin at.
will it fit the 3.3 revo and is it faster than a os tm?
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHLV9&P=ML[/link]
RE: for a buddy
I don't have a TZ, so I can't tell you whether it's good or not. But the one you listed has a rotary carb. You probably want the one with the slide carb.
PA
RE: for a buddy
I'd have to go with TM, because it is an easy drop-in and a great mill. The TZ is attractive, but unless there offerings have changed, I think it is generally setup for a bumpstart. I'm not sure but I don't think it mates well with the e-z start.
The 3.3 is not something I would even consider given the rash of conrod problems people have had with them.
RE: for a buddy
Heres the o.s. 18 tz you want.
its 130.00 but it will need to be bump started
http://www2.towerhobbies.com/cgi-bin...0p?&I=OSMG2110
AZ
RE: for a buddy
is the tz the one u all would go with? and if so how much is a bump start and how hard is it to do it? there is also the tm and the 3.3,
AZ
RE: for a buddy
so what would u all go with the tz, the tm or 3.3???? and y, what 1 has the most power??? and if we were to race with same trucks, with all 3 motors what 1 would win??? thanks
MT
RE: for a buddy
With the tz you have ot modifie the block, and i do not think the ez start will work eather, but you can get a rotostart backplate for it im sure.
IL
RE: for a buddy
I have 2 3.3's and an os .18 as well as an axial .28 for my revo's. In all honesty the OS motors are the easeast to tune...and the 3.3 is a pain!! But the conrod problem can be solved by swapping out the bearings with the Boccas. The bearings always seem to fail within a gal or so putting unneeded stress on the con-rod. But I have friends that are on their 3rd and 4th gal with the stock 3.3 and have had no problems. People always have a negative side, but never tell you the good about a product.
The 3.3 is a tad quicker than the os ni the long haul but the os is a lil quicker off the lone. It really comes down to user preference in my opinion. It's kinda like a chevy and ford debate.
Just my .02
Just my .02
MT
RE: for a buddy
No its not, chevys are faster, its more like ford vrs dodge, cause no one chalenges the bow-tie. Anyways if i were you i would get a sirio 23, since it comes iwht a header and engine mount that is anoed orange. Not ot mention it makes alot more hp then most 21s and more torqu then the tz, tm and 3.3. Itis a super high strung engine that loves to run at wot, but off the line it is fairly slow, infact it acts like an engine wiht a turbo, once it gets spooled up it runs like a raped ape. OF corse you have to replace the bearings in it wich sucks but i think it is still wortht. If the 23 is tomuch then i would look at the axial 28 and get a bb mount. Ii is not by anymeans a power house, but it does make more torque then any of thease small blocks or midblocks.
RE: for a buddy
http://www2.towerhobbies.com/cgi-bin...&I=LXKHE9&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXKHF4&P=M
Picco .26 max with mount shipped for $200 if you get them from towerhobbies.
