Car going at about 2km!!!
Old 01-02-2007, 04:27 AM
naynay12
Default Car going at about 2km!!!
Hi,for some reason just when i started my car up for about the 6th fuel tank today,when i press full throttle it goes not that fast only about 2km,it barely moves!!I think it could have something to do with the spur gear or other gear since my buggy is 4wd.When i manually spin the wheels the spur gear doesnt turn or that other turning thing on the engine doesnt turn also when it should.Whats wrong with my car?
Old 01-02-2007, 11:47 AM
Elite_Tux487
Elite_Tux487's Avatar
Default RE: Car going at about 2km!!!
"That other turning thing" lol.. Do you mean clutch bell? Well if you are pushing your car on the ground and the spur and pinion aren't spinning then mabey you broke something in the tranny take it apart and see if any of the gears are stripped or broken. Does your car rev up when you give it throttle and not go anywhere?
Old 01-02-2007, 06:34 PM
naynay12
Ok,whats the tranny?...lol
Old 01-02-2007, 06:37 PM
Nathan9492
Nathan9492's Avatar
transmission
Old 01-02-2007, 06:48 PM
naynay12
That seems to be ok,what else could it be,the spur gear???
Old 01-02-2007, 07:00 PM
Nathan9492
Nathan9492's Avatar
yes
Old 01-02-2007, 07:21 PM
naynay12
Ok i have phoned my lhs he doesnt sell 48tooth spur gear and since my car is two speed the other tooth is 43 tooth,do you know any online shops or anywhere that would sell these gears,i live in victoria australia?
Old 01-02-2007, 08:40 PM
CapUSA
CapUSA's Avatar
are you sure that's what is wrong with it? is the gear stripped? post some pics if you can.
Old 01-02-2007, 10:58 PM
Elite_Tux487
It can't be the spur since when he moves the wheels him self the spur doesn't spin. Either the axle pins broke..the shafts came disconnected, the pins didn't set right in the wheels or the tranny has a broken gear.
Old 01-02-2007, 11:19 PM
NITROHOLICS ANONYMOUS
NITROHOLICS ANONYMOUS's Avatar
some pics would help
Old 01-03-2007, 03:52 AM
scottywilkes
scottywilkes's Avatar
im thinking more along the lines that his flywheel nut may of come loose. I doubt its anything to do with the drivetrain. Also it would really help knowing what kinda car/buggy ortruck it is cause without that information its useless
Old 01-03-2007, 04:09 AM
naynay12
ok,its a vh-x5 nitro buggy 4wd 1/10 scale,basically the same as a smartech winner pro only the rims and body is different though the engine and even chassy is the same.Also what is the nut on the flywheel,where is it???Also when i roll the car along the ground sometimes the spur gear and clutchbell spins and sometimes it just stays still.
Old 01-03-2007, 04:14 AM
bte214
bte214's Avatar
The nut is inside the clutchbell. Ok when the wheels spin does your driveshafts? And your spur does not spin? Then it is definately in the tranny. Open it up look, in your manual then maybe you/we can diagnose your problem and you can learn more about your car too. And yes pics would help.
Old 01-03-2007, 04:20 AM
naynay12
ok,when i manually spin the back wheels or front wheels forward the spur gear and clutchbell does not turn..Also where is the tranny???lol
Old 01-03-2007, 04:25 AM
naynay12
Also when i spin the wheels any of them the driveshaft only turn a little biut it hardly turns at all.
Old 01-03-2007, 04:44 AM
con69
con69's Avatar
if the flywheel was lose wouldnt the motor stall since there is not momentum.
Old 01-03-2007, 04:45 AM
naynay12
my car does stall...
Old 01-03-2007, 12:01 PM
Elite_Tux487
In another thread you were talking about the wheels not setting right on the hub....Did you buy new wheels? If so its possible that the inside of the wheel doesn't take the hex adapter? Look inside the wheel and does it look like theres a space for a pin to go in or a hex nut? Or mabey if you took off the old tires the hex adapters stuck to the old tires and you didn't realise they were still in there? You also said that when you tightend the wheel nuts the spur gear would spin and the tires wouldn't so I would check to make sure the pins or hex adapters are fitting into the wheel.
Old 01-03-2007, 08:24 PM
it would help alot if ypu sent some pics of the car, we could then tell you where the tranny is
Old 01-03-2007, 11:19 PM
Elite_Tux487
I believe this is what he has http://www.nahpco.com/x5.htm
Old 01-04-2007, 04:32 AM
naynay12
Yeh elite tux487 is spot on.I took it down to the lhs,and he said that i was missing a nut inside the wheel hub.It was because i took out the wheel to see why my front wheel was wobbely, and i must have accidently lossed my nut or hex from the wheel hub.Thanks you guys for helping me.This car is a cheap car i have had 2 spurs strip,front wheel came off when i was just driving normally which i lost my dogbones and strppied a part near the front wheel,i have had 3 glowplugs foul,must not have much luck and it doesnt help that its a cheap car.Whats your opinion on my car,its exactly the same as a smartech winner pro,any opinions?
Old 01-04-2007, 12:01 PM
ross_jsy
glowplugs go all the time, nothing major. is the hex adapter still in your original wheele or did you lose it out of interest.
Old 01-04-2007, 08:42 PM
Elite_Tux487
If your having fun then its good. The quality of the car itself probably isn't as good compared to more expensive name brand vehicles but like i said if your having fun then who cares?
Old 01-05-2007, 01:21 AM
naynay12
ok,i suppose so,the only problem is that it never starts up i always have to clean my glowplug with a rag every time i start my car up,whys that? .Ross jsy,what do you mean?I lost my hex accidently and found that it was my problem.i lost it while taking the wheel off the car it must have dropped off.Thanks.
Old 01-05-2007, 01:49 AM
bte214
bte214's Avatar
What do you mean you have to wipe it off? Is there fuel residue on there? Somewhat like soot. If there is you are running too rich.
