runing in sand
runing in sand
hi guys wht do you recommend i do to my savage to run in the dunes and what tyres also hve any of you done this what damage have you occured
RE: runing in sand
i would highly reccommend the short paddles from proline. the tall paddles actually hook so good that most motors cant turn them and rapp them up. these short paddles rev up great and still hook great too resulting in better acelleration and top speed. these are 40 series tires though...
http://www2.towerhobbies.com/cgi-bin...?&I=LXLLL8&P=7
if you need 17mm 40 series rims, here is what we are running...
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
[link]http://www.axialracing.com/tools/local/imageupload/content/Thumbnail/size6/2b2e07ba55ceb047bda0ac2c3817f9b3.jpg[/link]
ive also got a video somewhere if you want to see them run.
NY
RE: runing in sand
i agree the paddle tires are probably best. do u have an aircomppresor? if u do cleaning it will be so easy just blow off all the sand. i will aslo make sure that the airfilter is on very tight. put a zip-tie on to keep the air filter around the carb neck, pull the zip-tie with pliers then cut off extra. keep it oiled good. and thats pretty much it
RE: runing in sand
ORIGINAL: benzzyo5
your body will prevent most sand from getting in your truck when upside down, just be sure not to pick the truck up and accidentally scoop a bunch of sand into the truck as flip it over.
