Question for Experienced Tuners
Hey Guys...
Got a tuning question.
I have my Savage X tuned very nicely... I think. Max temp is 250F.... tons of power... runs great bottom and top end. My problem is initial cold start. I could crank and crank for 2-3 min before it finally fires.
- Fuel is good quality and no air in the fuel lines.
- Glow plug is MC-59 and in good order... igniter is charged up
- roto-start is charged up and turning fast enough
- it's not flooded
- when it starts... I have to baby the throttle for the first 10 seconds or so or it will stall. Once I've kinda cleared the 10 second mark... it goes like mad and has no problems until the next initial cold start on a different day.
Maybe too lean on the low end?
Experienced guys help me out please!
Thanks, Kelly
- it's not flooded
Thanks, Kelly
RE: Question for Experienced Tuners
The best advise I can give you is to turn your carb needles back to stock settings and adjust from there. I had to do this a couple time on my X. Could also be an engine air leak. Here are a couple of posts I found useful.
http://www.savage-central.com/ftopic6471.html
http://www.rcracersedmonton.com/rcra...Engine101.aspx
ID, IRELAND
ORIGINAL: Sav-X
you could pin that info on them sites,
exellent info there i learned a lot,
cheers.
ORIGINAL: someguywitasavage
Are you priming it properly? Make sure the fuel is getting to the engine before you try to fire it up.
I'll try a few things tomorrow morning... but it's kinda odd how long it takes to fire.
ORIGINAL: -SomeGuy-
Maybe not enough air is getting into the mix, sometimes i need to give a tiny bit of throttle to get it started.
Fun Fun....
Maybe I have just the same as everyone else, but I'm bugged by it.
NY
mine always wont start for awile in the cold.. i usally just heat it up with a hairdryer and richen it up little bit...
My thoughts exactly corona. I had to do that for the first time the other day as my savvy would not start cold either. Outside temps were moderate IMO but nevertheless..........
CT
i think its in the priming, next time you try to start it prime it with the throttle at wide open.
i think whats happening is when you prime it at idle there is not enough fuel to light it up. just 2or3 sec bursts should do it.
OH
Try leaving the glow starter on for about 30-45 seconds before you try to start it.
That will ensure proper heat to the plug helping ignition.
QC, CANADA
ORIGINAL: burnchassis3
Alright... it was 6 deg celcius... which is about 43F this morning.... I primed it as I usually do... then left the igniter on for about 1 minute. Then it took two 5 second roto-start spins and it was fired up! So it's all about warming up the engine a bit with the igniter.
Ran like a top today... finally got to use my new wheelie bar.... and I think I hit 3rd gear a couple of times. It was the first real run with the 3 speed. (last run I broke the rear pinion off my ramp within 10 min... and no spare parts. I like the 3 speed... lots of bottom end... goes like stink.
Today's thing is the Nova RC race clutches were hanging up... I think one of the springs unseated... they didn't seem very secure when I assembled it. (they're OFNA 1.0mm springs). So I'll pull the clutch bell and see if I can get the springs to seat a bit better. Maybe if I reverse the shoes... anyone done that?
Thanks for all the above advise!!
WV
You could try using a little hotter plug. I run OS #8 which is a medium-hot plug and my Savage fires right up within 2 seconds.
what i do sometimes if my trucks dont start, take the fuel bottle and squirt some gas down the carb. (take off the air filter and squirt some down there) it works pretty good for me
