Urgent PROBLEM!!!
Old 01-05-2007, 05:20 PM
Rs43EVOman
Rs43EVOman's Avatar
Default Urgent PROBLEM!!!
Ok, well got my Ta05 all wired up, and i just ran it. The car makes a very loud screeching noise, and it spins out very easily. I checked and once i move the motor away the drivetrain it is very very smooth, and i know my gear mesh is set correctly. Whats wrong??!!!
Old 01-05-2007, 05:40 PM
pythonfan
pythonfan's Avatar
Default RE: Urgent PROBLEM!!!
check inside the tranny to make sure there is a fair amot of grease or lube! my rs4 was the same it would go but it would squeal like a dying cat and i had no control over it, just a little vasaline/patrolium jelly on the gears put the tranny back together, drop in the car and problem was fixed! It could also be the diffs may be to tight and that would cause a squial as well and would also make the car pull to the left or right and spin? This happens on my mini t so make sure ur wheel nuts r not on to tight that can also cause ur problem! are the wheels spinning freely?
