Winter build up date Aeromarine Signature 57 pic's
NY
xxxboatworks sent me his NEW exhaust tips, just put them on today. Tell me what you think of them !
MH$ Large trim tabs,Wal mart fuel tank is installed, flex shaft cross brace .
I added two Bonzi air scoops to the hatch, Bonzi driver and throttle men Figures, Aeromarine hatch locks.
Steve
Steve
NY
RE: Winter build up date Aeromarine Signature 57 pic's
Thanks G-1
I can't take all the credit, Raj xxxboatworks, has been very helpful.
What do you think of xxxboatworks new exhaust tips?
Steve
Steve
NY
ORIGINAL: crazyotto
looks nice . i like the tips too!! are those tappered ??
yes they are tappered, I think Raj did a nice job with them.
I like them much better then Bonzi's tips.
Steve
My Feedback: (19)
NH
Very Nice Steve !! Looks good
What was the part # for the Bonzi scoops and what are the dimensions and cost? Looks like they might work on my GTX.. Thanx, Tom H.
You should be ready for water soon !!! Tom H.
NY
ORIGINAL: Lakefrontlivin
I have you to thank as well, I got some ideas from your build pic's you posted.
I lowered the scoops in the hatch 1/2 inch. Scoops should great on the GTX .
BONZÃ Air Scoop part # BZSC1 - WHITE
Made from fiberglass in black, red, white or yellow.
4 1/2" long x 1 5/8" wide x 2" high $19.95/each
Steve
NY
I did some more work on the Signature 57 today
I installed through hull water pickups and returns.
Started running all the water cooling hoses.
Tuned pipe is about 3/4 inch away from the hull, so I added a aluminum heat shield with insulation behind it.
Steve
Steve
ORIGINAL: Ultimate48
Thanks G-1
Steve
Thanks G-1
Steve
AZ
steve how are goingto mount the electrical box? and where looks like alot going on in that area. looks great though i cant wait to see it live
NY
Thanks G-1 and crazy
I'm trying to build it the best I can.
Exhaust tips are new and I think I'm the one first to get them, thats why I asking everyone their thoughts .
Radio box is a problem, I started making one, not done yet !
Steve
Steve
NY
ORIGINAL: saleens7
i see 6 water lines, but only see 4 places for them to go...whats the other two for?
Are all four tips useable or just the standard two?
saleens7 & G-1
All water lines are used. Bonzi water cooled jackets have 2 lines in and 2 out on each jacket.
4 cooling lines out from the jackets and 2 from tuned pipes.
Silcone line is covering 1 water nipple in picture.
Exhaust tips on the left are used and two on the right are just going for the ride!
Steve
NY
Hi Steve... How about a box like this? Took some thinking t get it right but seems to work OK.. Tom
Hey Tom
Thanks, believe me I've been looking at your radio box for days now.
I can use a box like yours and it will fit.
What is the dimensions of the radio box and were did your get it.
Also what servos are you using for steering the outdrive ?
Steve
My Feedback: (19)
NH
Hi Steve,
The Box was made by Dr. Buck.. You can get them at gaspartsplus or CC Racing.
They run $28 .
The steering servos I'm using are dual 648 Hitecs i think.. Standard size but high torque.. They seem to work fine .. I'll know this spring for sure.. .. LOL Tom
They run $28 .
NY
the prop came today , Stainless steel from VooDoo looks nice. Very shinny
7018-2 SS I will try it out
I also got a 7016-3 SS to try
see what one works best.
Steve
Steve
Looks good steve...made any further progress? Boat should look pretty scale once she's in the water. Have you had a chance to fire up the motors yet?
NY
ORIGINAL: xxxboatworks
Thank you for the compliment and all the help and advice you have given me !
No, I have not fired them up yet . I have made some progress in the past week though.
Servos are in and working, nice to finally see the drive move on it's own.
Planning on starting the engines this weekend, if weather permits maybe a test run? I sure hope!! snowing today! [&o]
I will update pic's this weekend.
After test run ? I'm taking the Sig all apart and getting it ready for paint. Should look cool !
I have to finnish the Sig so I can get started on the MTI cat, I now have everything to get the MTI done.
I have another winter build starting after the MTI is done! Well, half a winter build, you know what I mean !LOL
Again I have to thank you very much, the blue inlines came out mint! They look great in the MTI cat!
Steve
NY
ORIGINAL: 45deepvee
where did you get those water pickups?
ORIGINAL: jimmy77433
Ultimate48,
Where did you get the RCM oudrive from?
Jim
Ultimate48,
Jim
xxxboatworks has them! water pickup's and RCM drive too!
Steve
NJ
Steve,
That boat rocks.
Now you can understand why I got you and Tom confused. Same boats.
Better get to work I'm already craving another update.
Rick
That boat rocks.
Rick
NY
ORIGINAL: yeeharacing
Steve,
That boat rocks.
Rick
Steve,
That boat rocks.
Rick
Well your close, Tom has a 65" expresscraft GTX with Zenoah inlines and MHZ drive
I have a 57" Aeromarine Signature with Zenoah inlines and RCM drive
I looked at you new boat, nice. a little work, it will be a great boat.
I have my work cut out on the next build, I'm starting it next week. I have to get this one done for the fun run. [>:]
Steve
