Got the 3.3 Revo Today
well, i got the 3.3 Revo and im quite pleased the revo is a great truck, but i am new to nitro and after i broke it in the accleration is good, but not spectacular, i havent touched the carb needle settings yet after 7 tanks, how will i improve this? i know i need to lean it out, but how far do i turn the needle and what direction? sorry this is a real newb question, but i need help.
Thanks guys
Thanks guys
LA
RE: Got the 3.3 Revo Today
ON, CANADA
The Revo needles are set to RICH from factory for the breakin process. You will need to tune to performance after the 5th tank. LEan the needle in 1/8 increments clockwise until performance increases. Make small changes and run the truck for a minute to ensure the excess fuel is completely burned out of the motor. Make more adjustments if necessary. The 3.3 motor will only get stronger as your tanks increase. This motor usually doesnt really start to wake up until after the first gallon. Try and keep your temps in the 220-250 range if you can.
