Lancair 360 MK2
NM
Lancair 360 MK2
Hi
I'm interested in buying one of the Nitroplanes Lancair 360 MK2 planes, and I'm wondering if it would be possible to run an OS max FL70 4 stroke in it. By that I guess I'm asking how much prop clearance is there? That engine uses a 12" to 13" prop.
Thanks! AlanP
Thanks! AlanP
My Feedback: (14)
RE: Lancair 360 MK2
I'm putting one together with an MDS68.
It appears to be about 8.5" ground clearance to the prop shaft so even a 13 inch prop should be ok.
Overall it looks pretty good for an inexpensive ARF.
Getting a wider engine entailed making clearance in the motor mount so it could go against the the upper nose gear block with clearance to get at the collar holding it in place. The engine is a tight fit and I'll probably have to cut up the cowl quite a bit.
I expect to have assembly done in a couple more days.
Eric
Eric
My Feedback: (14)
RE: Lancair 360 MK2
Some things I noticed in the construction.
Need to make clearance in the motor mount for the nose gear on an MDS 68 or any large engine
Dont forget the 2 washers under the left side holes of the motor mount to get the thrust (not built into firewall)
CMP measurement for face of prop to firewall too large - measure first - I have more than 1/4" gap - I'll leave it for now
With the large engine I needed tail weight so I cantelevered the 2100 NiMH 5 cell pack off the back of the servo tray in the middle of the Fuse with a Lowes paint stirrer - this will reduce need for dead weight in the plane - at 70mm will target 72 - 75 from leading edge by adding a little more weigt to the stirrer.
Trying TowerPro Digital (they call them digital) w/995 MG - better than expected for $13 ea.
Put the nose wheelpants on before putting the gear on the plane.
Zap a Dap a Goo works well for Front wheelpants components as well as rear windows (dont use old glue in a 40 degree garage)
Replace the wing screws with 1/4 - 20 nylon - ease of replacement
Elevate the rudder servo further and cris cross the rudder pull pull wires to get the right exit angles as well as the rudder matching the correct steering direction
Make rod standoffs for steering and throttle servos as appropriate - did not use one on the rigid (CF) elevator rod
First pics
First pics
NM
RE: Lancair 360 MK2
Wow!
What a slick looking plane! Thanks for the pics and the construction advice. That cowl really hides the engine well, doesn't it? So you think it'll cool ok? I hope so, that's really clean....
I'm hoping to get one on the way before too long.
NM
RE: Lancair 360 MK2
Eric,
please let me know how it flies, I've been reading posts on here about the CG being off (aft) as indicated on the plans, and the nose gear being a little weak. Everyone loves the way it flies though...
Man, what a clean plane..
IL
RE: Lancair 360 MK2
Hey guys thought I would chime in on this little gem. I have the stars and stripes version. First off this is a sweet flying plane and very responsive. I run a GMS .61 in mine and it hauls a@@. Landings are a little hot so be prepared. The plane is so aerodynamically clean that it takes a long time to bleed off speed. Just make a longer landing approach than normal and you will be fine. The plane comes in extremely nose heavy when using the .61 size motor so a lot of weight had to be added to the rear. I will post pictures. He is right about the distance from the engine backplate to the firewall. It is way off. I also have 1/4" gap and it looks ugly but I am going to leave it because it would require rebalancing. I can save you both the trouble of rebending the front landing gear, just replace it now. Way too weak. I fly off grass and it is cut extremely short and the wheel pants had to go. That sucked because they look sweet. If you insist on using the stock front gear and the wheel pants the first time it bends it will crack the bottom of the fuse. Ask me how I know. Once you get her trimmed out it is an awesome sight in the air. Very fast and nimble. Rolls can be very fast if you choose and loops can be as well. If you want to know the measurements of the control surface movements that I have just let me know. I can try to answer any more questions that you think of. Good luck on the maidens. One more thing I almost forgot. On take off the plane actually sticks to the ground. You have to fly this one off. Be careful because at takeoff speeds it can get squirrley as she has a short wheelbase. I flipped a couple of times figuring this out. RCU won't let me upload pics. I will try later.
My Feedback: (14)
RE: Lancair 360 MK2
Hey virtual,
Please post actual throws and cg you are flying with. Pictures would be great also.
Based on your experience, i'll probably use the current nose gear for show and drop in a spare Fults (dual leg) nose setup for flying.
Cheers
Eric
Going to be making more room on the ceiling of my garage for more planes - picked up 2 more at a club swap meet so im up to 29 - see my planes thru my profile.
Cheers
Eric
NM
RE: Lancair 360 MK2
Hey guys
Ths CG issue and the nosegear being weak were the two most prevalent concerns I've been able to find so far. When I get mine I'll take care of the nosegear before I do anything else. I would really like to install one of those nosewheel brake setups that Dubro makes (or used to make, I can't find 'em), it was sweet, worked great. Sure makes the runway 'longer'. I keep reading that retracts are not possible on this bird, but we'll see.....
Anyway,I'd love to see it.
Later! AlanP
Later! AlanP
IL
RE: Lancair 360 MK2
I will try to post pictures. The c.g. I am using is 72mm spot on on the great planes c.g. machine. The elevator has 8mm of movement both directions. The ailerons 10mm both directions. Max throw on the rudder. Believe me that is more than enough to control it. This provides very good roll rate and believe it or not tight loops if you want to.
RE: Lancair 360 MK2
Hi there guys well my bird did have the same ploblems with the nose gear, but for the CG it was 21 grams needed in the tail to have her CG,im flying with a ys fz63 super charged four stroke swinging a 11x8 prop and man is it fast !take offs are easy but landings are really fast and im on a asfault runway thats long.i`ve had mine for about a month so for and i love it im planing to replace the nose gear but unsure whats a good choice for this fast mover, please help P.S. here are some pics of her
UT
RE: Lancair 360 MK2
Virtual; I've got the ARF and will start building soon. It's been years since I've built anything. What did you use to replace the nose gear? I'm putting in an OS 45. Any other changes you've made would be appreciated.
Thanks Ron
Thanks Ron
RE: Lancair 360 MK2
Hi all
I fly an electric version with this adjustements (flying weigth 2636g)
CG 70 Ã* 72mm (fly very well)
Ailerons +/-8mm
Rudder +/- 25 mm (+/-35 maxi)
Elevator +/8mm
Airbraks -4mm
whish that help you
Greetings
Bernard
Ailerons +/-8mm
Elevator +/8mm
Airbraks -4mm
whish that help you
Greetings
Bernard
RE: Lancair 360 MK2
bungymania What motor are you using? My son (13) JUST CAME BACK FROM A FRIENDS HOUSE AND BROUGHT BACK ONE OF THESE. iT WAS SET UP FOR GAS BUT ALL WE FLY IS ELECTRIC. i WAS GOING TO GUT THE ELECTRISTAR TRAINER WHICH IS A 40 SIZE ELECTRIC WHICH SHOULD PULL 5-6 POUNDS WITH A 14.8 LIPO. hOPEFULLY IT WILL WORK BUT NOT SURE YET AS i JUST LOOKED AT THIS THING. kIND OF GOOFY LOOKING BUT HE IS EXCITED SO i WILL SEE WHAT I can do I just realized caps were on and I apologize I dont feel like re-typing. Thanks
RE: Lancair 360 MK2
Hi kobijust
Like you, i think 4S lipo is the good way to powered this plane (power/weight).
I use 2 setup on the Lancair 360
First setup: battery Hextronik D9 HXT4100 (only 12C !) 14.8v , Turnigy motor 42-50 (700kv) 12x8 APC E (37.3A 535Watts 8845rpm 2156g pull and 86km/h). The lancair is 2636g weigt and fly 8 minutes.
http://www.hobbycity.com/hobbycity/s...idProduct=2099
Second setup with a better battery Zippy H 4000 mAh 14.8v and Turnigy C5045-890 (890kv) 12x6 APC E (54.9A 830Watts 10290Watts 2989g pull and 75km/h). 11x7 propeller for more speed.
http://www.hobbycity.com/hobbycity/s...idProduct=3889
http://www.hobbycity.com/hobbycity/s...5C_Lipoly_Pack
esc: 60 to 80A opto + ubec
You can have more info on my web site, please take a look here.
http://www.bungymania.com/lancair/indexposiessai.php
Greetings
Bernard
Greetings
Bernard
RE: Lancair 360 MK2
ORIGINAL: bungymania
Hi kobijust
Greetings
Bernard
Hi kobijust
Greetings
Bernard
TN
RE: Lancair 360 MK2
I JUST purchased one of these. Got the blue & white by accident because they shipped me the wrong scheme,.. but it's still nice. I've stripped my electronics and Evo .46 from my other plane,.. and was wondering if anyone knew of a better "step by step" assembly instructions for this plane? As this will be MY 1st real assembly...
TN
RE: Lancair 360 MK2
Ok,.. I'm understanding the build better than I thought. I've gotten the motor installed properly, and cut out the cowling, I've also done the flaps' little hinges glued, the rear wings put on,and the wheels put together.
I have to wait for the main wings till a few servos come in on order. The Alpha 40 which I removed the engine and electronics only had 4 servos,.. and I need 5. And from what I see servo wire extenders.
I had to use other wheels I actually had spare. The wheels they sent with the plane were NOT correct. 2 might have worked, but the 3rd looked like a tail wheel... tiny. It makes me wonder if the right fuel tank is in the box, because it was in with the wheels package.
I also was glad I had a package of spare flap "hinges"... one wing flap was missing one hinge, and the tail center vertical flap was missing all 3.
Ok,... so here's my questions...
1st,.. what glue would you recommend for the motor throttle servo mount? I don't like cheap crappy epoxy. I like stuff I can trust 100% I'm actually thinking Gorilla Glue...lol
2nd,... The rear elevator options for the cable. "Can't adjust gearing" and "adjustable gearing" what's that mean?
TN
RE: Lancair 360 MK2
I'd actually like to see more picture of peoples Lancairs done. I'm getting close to finishing myself. All I have left are rear control cables, wing flap settings, and a few minor details,.. oh and mounting the front wheel assembly.
