How to take a flywheel and tighten the slipper clutch?
Hi,just wondering how do you take the flywheel off,and to tighten the slipper clutch do you just tighten the nut next to the spur gear?
ON, CANADA
RE: How to take a flywheel and tighten the slipper clutch?
Remove the clutch bell, clutch and clutch nut, then use a gear or battery terminal puller and use it on the flywheer, alternatively you could softly tap it with a rubber hammer.
The slipper should have a hex nut, tighten it to tighten your slipper.
