New Building Table
New Building Table
Old 01-20-2007, 09:54 PM
flynte
Default New Building Table
Needed more building space. Built out of 1.5" square tubing with 3/4" MDF and a replaceable 1/4 hard board on top. It also can be tooken apart if I need more room in the shop.
flynte
ID:	602792   Click image for larger version
ID:	602793   Click image for larger version
ID:	602794   Click image for larger version
ID:	602795   Click image for larger version
ID:	602796   Click image for larger version
ID:	602797   Click image for larger version
ID:	602798   Click image for larger version
Old 01-20-2007, 10:15 PM
Bart[man]
Default RE: New Building Table
Nice table you got there flynte. How much did that puppy set ya back? I'm thinking about the same table top frame, but due to verrrry limited space i'm going to piano hinge it to a wall so it can lay flat against the wall when it's not in use. Bart(man)
Old 01-20-2007, 10:33 PM
flynte
Have about 380.00 in materials. Took about 7hrs to build.
flynte
Old 01-20-2007, 10:38 PM
bigugly
very nice ........I wish I had a table like that ( and the space for it )
Old 01-20-2007, 10:42 PM
Bart[man]
OUCH!!!! But it's still nice. I'm a steel fabricator by trade so I'm shurr I can get a brake on the alluminum. Happy building. Bart(man)
Old 01-20-2007, 11:20 PM
saramos
saramos's Avatar
How about topping it with a sheet of cold rolled steel and build using magnets instead of pins?
Check out Paul Johnsons article on building with magnets.
http://www.airfieldmodels.com/inform...oard/index.htm
Scott
Old 01-20-2007, 11:57 PM
flynte
My other table is sheeted with steel. Use if for planes and welding on.
flynte
Old 01-21-2007, 01:16 PM
Cryhavoc
My Feedback: (46)
Cryhavoc's Avatar
I really like your table. What size is it. It looks like it'd be just right. What kind of hardwood top did you use and will you lay something over that to stick your T-pins into?
Old 01-21-2007, 02:31 PM
flynte
It's 3.5' x 6'. The two shelves are MDF board which is a very dense particle board. On the top I also added a 1/4" hard board, same as peg board material that is coated with varathane to seal it. I was looking into finding some good cork board to lay over top for pinning, just haven't got that far yet.
flynte
Old 01-24-2007, 11:38 AM
Kevlar
My Feedback: (47)
Kevlar's Avatar
Nice table Flynte! I'd like to build a table as well - What type of welder did you use (if at all) and what would you recommend for the beginner to purchase. Nothing heavy duty for me...
Old 01-27-2007, 06:47 PM
flynte
Used a mig welder for it. I have a Hobart 135 (Miller makes them). I think the model is 140 now. It's a great first welder and beyond.
flynte
Old 01-31-2007, 06:38 PM
Mikel-t
My Feedback: (12)
Flynte, I got started on my first steel top table and am using magnets instead of pins, works great. Now I need some insight on where to look for a real piece of steel instead of this metal cabinet door ( too flimsy 1/16th) I've tried fabricators,etc. and no luck...I've even found a vendor off the Web. https://www.discountsteel.com/index.cfm/go/ but it seem kind of expensive, Got any ideas for sources?
Old 02-01-2007, 12:20 AM
flynte
When I built my other table, I got the metal through our shop, 4x8 x1/8" plate, for cost. It was about 235.00 for the sheet. Steel prices are absolutely crazy now. We get the steel from Westeel in Edmonton.
flynte
